Kyo_kusanagi86
- Mar 13, 2001
My aftershock titan still running strong, 4th Gen i7 4910MQ, 980M GTX SLI. But hands itchy to get another desktop replacement laptop.
If you plan to hang on to your laptop for 3 years, then I think it's worthwhile to get the extended warranty.Was considering between Apex 15X $2545 (i7 10870, RTX 3060, 16gb ram, 1TB SSD) and Alienware M15 R4 $3649 (i7 10870, RTX3060, 16gb ram, 1TB SSD) to replace my 5 yr old Razer Blade 15.
If taking AS, is it better to upgrade to the 3 yrs parts warranty?
My razer serve me well over 5 yrs, just that the battery became bloated on the 2nd yr.
Is it recommended to top up to get the Alienware?
If you want to better managed the temp better, remove your laptop base cover and use it on a simple laptop stand with cooler/ fan. This will easily bring down 2-5 degrees.I am using Apex 15 Lite and temperature goes to 95 when gaming.
Heard about using Throttlestop but the gaming center that comes with the laptop, do I need to uninstall it as i think it probably might also meddle with the CPU seeing the different profile it has actually change my cpu speed. But it also enable the OSD, i.e showing caps lock, num lock.
Anyone got advice if i should do away with gaming center?
If your laptop CPU/ GPU is hitting 95 degrees under load, I don't recommend using Throttlestop. While it is good for performance, the reason the system throttle is to avoid damaging the components when it hits a certain threshold.I am using Apex 15 Lite and temperature goes to 95 when gaming.
Sorry have not logged in for a while. The slim format of the notebooks made it impossible to have detachable battery. Not on the model I have.Does AS laptop still come with a detachable battery ? worthy a consideration b'cos battery will die first after a few yrs.
Boss..how is the batt life?
Based on what you typed, aftershock had already been damn nice Liao. I’ve no idea what’s the complain.Prime 15 i7 7700 HQ + GTX1060
First year - 2017 - BSOD keep happening, can't reproduce when at AS, found out it's the memory that's having issue (is it Crucial memory that AS using?)
First year - found casing creak to the left of the motherboard, AS said chasis design nothing can be done
Second year - BSOD continued happening, the rest pretty normal
Third year - 1 month after Warranty - Found out some keys not working - went to AS, quoted replacement keyboard at $99 (Can't really remember TBH) - decided to not replace
Fourth year - more keys went dead, found out pressing the area slightly below spacebar helps with the key recognizing
Fourth year - found out that the chasis deformed, decided to open it up, found bloated battery (always used on charger and charger only, running on battery < 20 times
Fourth year - fan started giving some noise sometimes, opened up found out 1 GPU fan not turning freely already, went down to AS asking for a service, was informed need to wait 3-5 days for the service (due to exponential growth of number of customers, compared to instant 1-2 hours on the spot service few years earlier) - decided not to wait, was busy at that time too
Fourth year - finally did a memory diagnostic after numerous BSOD finding out that it's the memory that's causing the BSOD all this while - replaced 1x 8GB DDR4 SODIMM, BSOD went away
End of Fourth year (this year) - HDD starting showing sign of aging and making sound - was working alright then suddenly stopped transferring files - still able to see file list but hardly getting any files copied - read head issue likely
Into Fifth year - the GPU fan stopped working properly suddenly giving super loud noise one day, can't even game a bit it will start making that screeching sound once temp > 70c.
My experience with Aftershock.
One good thing though, when I asked AS about the price of getting the GPU fan repaired, they asked to send it in for a Free Service. Will I get a free fan replacement? Fingers-crossed.
TL;DR
I will go back to a main brand laptop if I ever decide to change my Prime 15. Its performance is still more than capable for my usage but all the build/quality issues made it a let down for me. 50:50 for their service, got good and bad.
As I said there's good and bad. I have to say I expected better product quality though. Besides that, I decided to get AS previously due to good reputation on the service. Understand that it's still offering the service but due to increased demand they are not at the same level as many years back. Anyway, it's just a sharing of experience. Hope that they've gotten better OEM models. I may be unlucky in getting this model too. The Clevo model for Prism 15 has the same problems with keyboard and fan all over in other forums too.Based on what you typed, aftershock had already been damn nice Liao. I’ve no idea what’s the complain.
Go back then to your mainstream brands, and see what happens after the first couple of years even if you still have warranty.
he complaining meh? only describing what he experienced in a series of event whatBased on what you typed, aftershock had already been damn nice Liao. I’ve no idea what’s the complain.
your keyboard what happen? mine many keys need slam to register keystrokeAs I said there's good and bad. I have to say I expected better product quality though. Besides that, I decided to get AS previously due to good reputation on the service. Understand that it's still offering the service but due to increased demand they are not at the same level as many years back. Anyway, it's just a sharing of experience. Hope that they've gotten better OEM models. I may be unlucky in getting this model too. The Clevo model for Prism 15 has the same problems with keyboard and fan all over in other forums too.
Yup. Am just saying if want ‘quality’ den go buy normal Brands. But for the same spec it’s totally different in price.he complaining meh? only describing what he experienced in a series of event what
at some point this OEM selling not sustainable la.. this not selling any other stuff in sg. oem problem end up become your brand problem.Yup. Am just saying if want ‘quality’ den go buy normal Brands. But for the same spec it’s totally different in price.
pray it’ll never spoil…
Many keys not registering. I found a trick to press around spacebar area will make it register, just press that area those keys can type as usual. My guess ah... The battery went bloated and somehow pressed against the keyboard, may have caused the ribbon to damage and eventually causing bad contact/not registering strokes. The trick still work right now if I need to use the keyboard but most of the time I'm running on external keyboard already since the laptop is now basically a desktop with the battery taken out.your keyboard what happen? mine many keys need slam to register keystroke
