Xiaomi Routers: Xiaomi BE10000/BE7000/BE6500 Pro/BE5000/BE3600, Xiaomi AX6000, Redmi AX6000, Redmi AX5400/Gaming, Xiaomi AX3200/AX3000, Xiaomi AX3000T
In China market, Xiaomi AX6000 faces strong competition from TP-Link.
TP-Link XDR-5480 is an interesting product, it has very good wifi hardware and wifi performance. It has also proper 2.5G port, unlike Xiaomi AX6000 has a not so good 2.5G port implementation. But then the TP-Link has only 256MB RAM and 16MB flash. So it is probably more suitable as an AP.
Chinese review:
shin89
Quick question on setting up AX6000 as AP.
My current setup is M1 ONT > Edgerouter > AX6000.
Seems like my edgerouter is on 192.168.1.1 while AX6000 is on 192.168.31.1 - wireless internet works fine.
After turning off DHCP on my AX6000, my wireless internet is down. What am I missing here?
Feel like I need to manually set a static IP on the AX6000 before turning off DHCP.
Easier is to factory reset the AX6000 and then set up the Internet as AP mode aka "wired bridge mode" (有线中继模式).
luwize1
Does anyone know if I can actually setup additional SSID for the router? Aside from the guest mode in App, and seemingly the guest mode is only 2.4ghz
shin89
Thanks xiaofan, did just that and was able to setup as AP mode via the Mijia Home App. Always thought it should have been wireless AP, thanks for clearing the air!
Great piece of equipment so far!
shin89
If I were to add a second AX6000 for mesh WIFI, i'm guessing its setup the same way?
Redmi AX5400 Gaming Edition: this is a good replacement for Xiaomi AX6000 as it fixes the 2.5G Lan port issue and it looks nicer as well. Take note it has only China version, same as Xiaomi AX6000. Both are priced at RMB599.
https://www.mi.com/rm5400
Review and tear-down in Chinese. HW spec is basically the same as Xiaomi AX6000, with the change of the switch chip to fix the 2.5G LAN port issue.
https://www.acwifi.net/18840.htmlhttps://www.acwifi.net/18859.html
Chinese Youtube Review of Redmi AX5400 Gaming Edition with comparison with some other popular mid-end AX routers in China, including Xiaomi AX6000, TP-Link XDR-5480, H3C N54 and ZTE AX5400 Pro.
Xiaomi AX3200 and Redmi AX6S are using MTK7622B solution. This may give them higher chance of getting official OpenWRT support since the support of MTK7622B has been there now.
https://www.acwifi.net/16612.html
Price of Xiaomi AX3200 global version is about S$89, similar to Xiaomi AX3000 global version. Each has its stronger point. Xiaomi AX3000 is a safer buy with Qualcomm CPU and local warranty.
Xiaomi AX3200 at S$89 from official Xiaomi Shopee Store with local warranty.
Check out [2022 New] Xiaomi Router AX3200 - Wi-Fi 6 / Support 4x4 MU-MIMO at 25% off! $89.00 only. Get it on Shopee now! https://shopee.sg/product/237295326/14553021402?smtt=0.568370204-1647783062.9
SSH guide, OpenWRT snapshot version is also available.
https://openwrt.org/toh/xiaomi/ax3200
So far there is no SSH hack for Xiaomi AX3000 and Redmi AX3000. Redmi AX5400 Gaming and Redmi AX5400 are too new so there is no SSH hack either.
Other than that, there are SSH hack for most of the Xiaomi AX routers, like Xiaomi AX9000, AX6000, AX3600 and AX18000, Redmi AX6, Redmi AX6S and Redmi AX5.
How is Xiaomi AX3000 compared to AX3600 or AX6000?
They are in a different league.
Xiaomi AX3600: much faster CPU, better wifi coverage, best value at its listed RMB499 price, unfortunately no longer manufacturered, so the price is very high even if you can get it.
Xiaomi AX6000: better wifi performance and coverage, no global version, price in SG online stores has relatively high markup from the RMB599 listed price
Xiaomi AX3000: lower performance but also lower cost, global version with local warranty, very good buy for the price as of now
