Pocophone F3
luei74
Look like the F3 5G 8/256 no longer listed at Shoppee page. Only left with the 8/128 still available, could be final batch for the up coming 6.6..
8/256 back on May 10 with white colour only, total 19x sets 🥳
twosix
https://www.notebookcheck.net/Poco-...p-ahead-of-launch-as-specs-leak.618699.0.html
As reported by Mukul Sharma, the Poco F4 has now been certified at NBTC—Thailand's National Broadcasting and Telecommunications Commission. The device applied for certification a while back, and now appears to have finished with the process. According to the same source, the Poco F4 will be available with 6 GB and 8GB RAM, and up to 256 GB of storage. It will land with an Android 12-based MIUI 13, will feature a 4400 mAh battery, 67 W charging, and a Snapdragon 870.
Seems like the F4 will also come with SD870.
TheOutsider
Hailgod
why so rushed to update to miui13? ive heard nothing but bad things about it.
No new features, just tons of new bugs.
Deathzz
been using it, so far so good. feels battery life is decent too. depend on your use case for those bugs encountered..
Plastick
go taobao search for monqiqi brand of tempered glass protector.... they are oneof the best glass i use... touch is smooth and glass is of good quality
F3 also got monqiqi tg sp? remember u were also recommending mqq for k20 pro back then. cant find on TB leh for F3.. or has to get the redmi k40?
KeYoKe
Recommend ibywind... Cheap and good. Buy from lazada at 7.99. comes with 2 pieces of TG, 1 back carbon fibre protector, camera protector and installaion kit
