Oneplus Ace/10R
Loser
Better deal at Qoo10 Geekermart,
For 12/256GB 160W version:
$639-$55(cart voucher)=$584
Use Q*coin buy can get additional 10%off which is
$584*0.9=$525.
They provide 6 months warranty from HK so I dunno how to claim warranty etc... I never buy from them before. A few years back quite a few EDMWers buy from them have good reviews, dunno about now.
See any bros can feedback on seller.
clydeteo22
Can anyone enlighten me as I'm been trying to find a definite answer but to no avail. Does China Rom definitely won't have Widevine L1 hence won't support Netflix HD? Been wanting to get a CN phone but am worried on this.
If so, does a global ROM always have Widevine L1?
I only know for sure local sets won't have this issue but alot of phones aren't available locally
waterballoon
I somewhat asked a similar question in another thread. the phones that are worth considering like 9R, 9RT, 10R are only sold in CN and IN. Getting IN set is out of the question.
so we get sold CN sets flashed to Global ROM. A long long long time ago, OP used to be very easy to change ROM, just download into phone & use system updater to flash then do clean reset.
Nowadays, that updater is gone and to flash other region i think u need to unlock bootloader. Allegedly, so long you lock back, ur safe but aaftr redaing numerous complaints/confusion from others online, i think lock back bootloader aslo no L1.
and confirm CN no L1. they don't need it anyway..
clydeteo22
Tks so much for your help. Was thinking to get the Oneplus Ace (10R) from the official Oneplus SG store from Shopee. They have mentioned its a Global ROM with Netflix HD support. Not sure if this is legit.
waterballoon
the only way to know is to check the DRM via an app.
in the grand scheme of things tho, if the price is right and every other spec is good, I wouldn't mind L3. I don't think i've ever watched a Netflix show on my phone before tbh lol
clydeteo22
Haha yea. But was trying to gamble that its L1 since Global ROM version cost $100 more than the CN ROM version. Would be a waste to pay more and still get L3
Loser
I think as it stands, it's better to buy OnePlus models with global release in NA/EU and sold through OnePlusSG local set.
There seems to be an issue with Chinese sets flashed with global ROM since hydrogen OS migrated to colorOS.
I still cannot find out the reason why from searching online.
JasK
New owner of ace. Got it from little India at 520. It's with oxygenos and 12/256 green back.
My 20x died and was looking to get k50 pro and decided to try this. Surprisingly fast and smooth and can use one hand surf and check emails. No issues thus far. 150w charging damn shiok after being stuck 4 years at 18-22.5w. 15mins enough to get it to 100%. But the 160w charger solidly heavy.
Partly get it cuz I wanted to try 8100max and 610...too bad no ready k50 pro to get cuz it's on 9000/710.
The speakers and sound still a notch below e 20x as it's not as define and clear especially if it's on full volume. Abit muddy at full blast
I was wondering the wrap cable any difference from other wrap cable since no indication. Is it really a 150w cable.
Loser
20V/7.5A so you need a cable rated to 7.5A to enjoy full speed.
JasK
But I don't see 7.5a cables available anywhere. Only 6a ones. So I wonder the original cable is rated at what. I try to test
clydeteo22
How's Netflix for your phone? Does it support HD playback?
JasK
The next way to check the HDR standard of your phone is via an app called, HDR Display Check. This app is very simple and clearly mentions if your phone supports HDR 10, HDR HLG, Dolby Vision, or not. Compatible Standards will turn Green, while the unsupported ones will turn Red.
JasK
HDR 10 or 10 Plus is the most common standard on the majority of phones, as they are free and easy to implement. While Dolby Vision requires a license and more challenging implementation, that’s why it is usually found on high-end flagship phones
raindance
No you need to install the app DRM info and see what is the widevine level.
