- Sep 16, 2018
Looking to get some opinions from experts here.
Currently i am on Starhub 1gb fibre bb and fibre tv(old samsung black set-top box) and using the Linksys EA8100 router issued by them back when i signed up for the plan. I am thinking of changing to a Wifi 6 capable router and saw many M1 issued TP-Link AX72 being dumped on carousell for below $100.
I am living in a 3 room flat and mainly use WIFI with no more than 5-6 devices connected at once so i don't really need a router that is too fancy or powerful. Might consider jumping ship to simba 2.5gb broadband when they launch so i feel the TP-Link AX72 suits my current and future needs nicely. I am assuming those M1 issued TP-Link AX72 should not have issues working on starhub fibre bb but is there a need for me to call up starhub and inform them about the router change? Any other recommended alternatives to the AX72 at around $150?
If you intend to use SIMBA plan which is a 2.5Gbps plan, TP-Link Archer AX72 is not really suitable since it does not have 2.5Gbps WAN port. And you will have isues sticking to your old Fibre TV box as Starhub will charge Fibre Link Access fee if you do not use Starhub Fibre broadband.
But it will work with Starhub without any issues. You do not need to call Starhub. It will work fine. Just turn off the Starhub ONT and the EA8100, remove the EA8100, plug in the Archer AX72, power on the Starhub ONT and the AX72.
