Expressway Facing or HDB facing?
Which?
  • 4th Floor Low Floor face HDB
    Votes: 14 40.0%
  • 13th Floor high floor; pool view Expressway
    Votes: 21 60.0%
  • Total voters
    35
Dracky
TS should go hang around some HDB units facing the expressway at night to get a feel of the constant drone of traffic.
Xihe
High floor better. Somemore expressway facing means unblocked views.
TONGDODO
Well, like what others have said, there are pros and cons if u wanna have the best of both worlds, so u might as well look for another unit other than these 2.
As I have always stayed tampines and this is an EC, so would naturally select this condo.
TONGDODO
My workplace is around 10-20m from the expressway below. I can hear the background noise from my floor (10+ storey), plus the car crashes that happen occasionally. That's with no windows opened.
I cant imagine what's the noise like with the windows opened.
Yup… I do understand 20-40 m is very noisy.
but not so sure about 69m, whether will it be very noisy.
have went to the site, but open air, not sure close space how will it be
magna_strike
Well, it's your choice so think carefully. Doesn't mean u die die must take it even if it's an EC. Frankly both options don't sound that appealing.
keenklee
Planning to get a unit but may be only left with some options..
out of these options, which will you pick? This will be an EC at Tampines Tenet.
1) High floor, pool view, but expressway facing (69m) $1370psf
2) low floor, hdb view, no expressway, same price as 1)
anyone with direct experience.. would appreciate.
thank you
IMHO.
I will choose Option 1.
Expressway don't run 24 hours. At night is actually quite empty.
Peak is 7.15am to 9.15am and 5.45pm to 7.55 pm.
Will benefit from the wind coming from the North a lot of time at night. Unlikely to be affected by Pasir Gudang.
If worry about noise and dust, close window and install air purfiers and curtains.
Punggol / Sengkang near TPE have some HDB, u may want to go there and take a look during the peak and non-peak times.
Opposite of the expressway seems to have condo with tennis courts - low blockage. Best is to face there.
Overall, face elsewhere is better than face HDB especially low floor.
yumsang
one thing for sure, the noise never stop ... so is just about how loud
airman88
Especially in the dead of night, traffic noise will be more pronounced.
If I were you, I will not go for the expressway facing unit as you may have problem selling later on.
1982-1994
thank you
Low SES HDB dweller reporting in,
Pool view so that you can beo chiobu swimming
Anyway the HDB view unit is valuable since it is priced the same as the pool unit despite the low floor...
toolbox03
IMHO.
Expressway at night will have siaolang motorbike or driver chiong full speed super noisy :s22:
shine0204
face HDB much better. Expressway 24hr noise-1am, 5am noise disrupts sleep. Expressway 6-8lanes much noisier than normal small/medium roads. Visually-our eyes on laptop/mobile, seldom stare outside windows.
TONGDODO
IMHO.
Thank you for your reply.
seems very torn over this as well. I would actually prefer expressway due to high floor + pool.
but seems like many many caution against the noise.
still not too sure
