As I have always stayed tampines and this is an EC, so would naturally select this condo.Well, like what others have said, there are pros and cons if u wanna have the best of both worlds, so u might as well look for another unit other than these 2.
Yup… I do understand 20-40 m is very noisy.My workplace is around 10-20m from the expressway below. I can hear the background noise from my floor (10+ storey), plus the car crashes that happen occasionally. That's with no windows opened.
I cant imagine what's the noise like with the windows opened.
Well, it's your choice so think carefully. Doesn't mean u die die must take it even if it's an EC. Frankly both options don't sound that appealing.As I have always stayed tampines and this is an EC, so would naturally select this condo.
IMHO.Planning to get a unit but may be only left with some options..
out of these options, which will you pick? This will be an EC at Tampines Tenet.
1) High floor, pool view, but expressway facing (69m) $1370psf
2) low floor, hdb view, no expressway, same price as 1)
anyone with direct experience.. would appreciate.
thank you
but not so sure about 69m, whether will it be very noisy.
have went to the site, but open air, not sure close space how will it be
Especially in the dead of night, traffic noise will be more pronounced.Yup… I do understand 20-40 m is very noisy.
Low SES HDB dweller reporting in,Planning to get a unit but may be only left with some options..
thank you
Expressway at night will have siaolang motorbike or driver chiong full speed super noisyIMHO.
I will choose Option 1.
Expressway don't run 24 hours. At night is actually quite empty.
Peak is 7.15am to 9.15am and 5.45pm to 7.55 pm.
Will benefit from the wind coming from the North a lot of time at night. Unlikely to be affected by Pasir Gudang.
If worry about noise and dust, close window and install air purfiers and curtains.
Punggol / Sengkang near TPE have some HDB, u may want to go there and take a look during the peak and non-peak times.
Opposite of the expressway seems to have condo with tennis courts - low blockage. Best is to face there.
Overall, face elsewhere is better than face HDB especially low floor.
Hdb a lot of ah lian screaming and fighting
Thank you for your reply.IMHO.
