Shake.Query
leongws
Support fibre. Router is set to router mode
**not sure got any port on Nokia ONT supporting SFP+ as i not sure how it looks like
**not sure got any port on Nokia ONT supporting SFP+ as i not sure how it looks like...
Just noticed the picture is a bit dark and not all labels can be seen clearly. Re-took another picture. Only connection I don’t know is the one circled on the left. Not sure is it for SFP+ as no label.
Mach3.2
Try to look into the grills at the area where the SC/APC patch cord goes in, see if you can see an SFP+ cage inside or not.
But from what I can find online, no SFP+ module inside.
No SFP+.
https://support.myrepublic.com.sg/h...o your router,should have no internet access.
21625025733145
berlo84
Update:
As my 2nd port is used for Singtel 5 years ago, I have called in to CSO to release the port.
ST agrees to release the 2nd port in the next few days.
Realising termination of service will not trigger the release of port.
yosemi
Ah I see maybe i think too much tot the ONT can have fiber out interface to a enterprise switch
loganrunning
Update:
slight off-topic here. a tip for those buying resale houses.
if the previous owner dun want to issue instructions to release the port, NLT won't (as seen by other stories here).
Hence, include release of port by previous owner in sale & purchase contract
ok, back to regular programming.
leongws
Do give a heads up if imda announce the green light for wifi 6e. I will then check with tp link on fw upgrade to enable 6e band.
Rumour iPhone 15 pro also support wifi 6e and will be released in September. Guessing the green light might be given around same period.
Shake.Query
Just got my MR hyperspeed ONT setup. Same Nokia XS-250X-A variant as leongws.
10GbE servers Speedtest results are close to expected (typical) speeds, but feels like Singtel Fibre 1GbE is stilll more stable (consistent), too bad they don't offer ONT or bridged setup anymore. International speeds tested is about 2Gbps Down and ~700Mbps up.
Waiting for the activation of 6GHz and iPhone 15 Pro Max 😂 to test WIFI 6E speeds.
TanKianW
Expect to see more forum-ers upgrade to 10G networking equipment as these plans become more common. (y)
okko00
sorry.. whats the network switch that you are using? thanks
