Japan sim card?
Panerex
Understand ICC supplied SIM cards are usually no issues. But I see for Japan some people complain about no connection in Osaka and Kyoto
any other sim to recommend? Will be in Tokyo Osaka and Kyoto for 11 days
hope the ICC issues are isolated
szeli
just got back from Osaka, Shikoku, Tottori. had good experience with Ubigi. 5G connection in a lot of places 👍🏼
ragnarok95
Senior Moderator
Senior Moderator
Sounds good. Mind sharing which plan u bought?
Ubigi 10GB plan for japan is USD17. With USD17 you could get bigger data plan in Shopee. But in term of reliability and such, i will pay to use Ubigi.
Humphrey5
Anyone knows why when I use Ubigi I cannot seem to get local SMS via my Primary?
I only switch on Secondary (Ubigi) and data from secondary. Theoretically I should still get phone calls/sms coming in my primary?
xdivider
phone model? my fren mentioned he had the same problem when using a esim to roam....
x3nor_S
Seems like Ubigi has quite good feedback based on the comments here. Am thinking of getting Ubigi and ICC to diversify the risk. I see ICC reviews all mostly good but there are a small number of reviews mention about poor connectivity or no network after a few days
Humphrey5
Am using iPhone 14 pro.
Otherwise no big issues with Ubigi.
I tested it out in JB to see experience before buying for upcoming Japan trip this month. But if cannot get SMS would be a bummer….
szeli
SMS? isn’t Ubigi data only? oh wait you talking about your pri line. it’s more likely an issue with your pri line..
szeli
not sure if I’m looking at the right prices but isn’t ICC much more expensive than Ubigi/Airalo?
x3nor_S
Ubigi is about 5 bucks more ex than ICC. At least from what I need. Approx 10gb for 12-15days. 4g is sufficient for me but Ubigi does offer 5g
Quasar
Ubigi worked for me, similar phone model to yours. Managed to receive SMS for uber app re-registration in September.
My primary remained Myrepublic mobile using starhub (5g esim)
Could be you blocked roaming either on phone or at the carrier app so nothing going through?
Humphrey5
Perhaps you are right. I did not turn on roaming on my Singtel roaming so maybe it’s this. Will on it to see if it works next time
Thanks
vaxvms
yes...china card are mostly 4g but reliable as well esp for half the price
so guess need pay more for 5g
Hisashiburi
Where do u get ubigi from?
Just run thr qr code from email n it works?
Never tried esim before
Tks
