7900 XTX or 4080 Super
NightRaven49
Have print screen but cannot capture the amd overlay so I take photo
wow, i didn't even know that :unsure:
Do you mean it hides itself when you capture it?
Yeah it will return to the game screen and disappear
hmm, i can screenshot the overlay no issue when using alt-prtsc (direct save to pictures/screenshots):
NightRaven49
BlackWing1977
I can only recommend 2 types of cables I have used and tested that has the least Vdroop. Cablemod ones I had issues with black screen and much higher Vdroop that I did not want to ever use that again.
Only 2 I would recommend if you want to use 12VHPWR :
1. Seasonic Stock PSU Cable.
They just announced they have come out with the 12V-2x6 version which I think AD may provide once you show your receipt for eligible models. I know mine is eligible but might take a while locally before they announce.
You mean local distro will provide?? I got a Vertex that came with the old 12VHPWR cable... but I did not use it as I was using 7900XTX.
BlackWing1977
yeah my skill cannot with win 11 and once i use the alt-prtsc this come out (amd newbie) :ROFLMAO:
It is the HDR causing the grey out issues, either turn off before taking screenshot or skip the snipping tool by using Alt-Prtscrn lor.. or you can turn off the function.
Then pressing Print Screen by default will capture everything on screen.
Yongkit
Nice tips👍
I use sniping tool alot because 3 reasons
1. More precise screen shot for area I needed
2. It directly save a copy of my screenshot in picture folder
3. I can directly edit and highlights my screenshot.
Now for the game I find the in game photoshoot also quite good.
I will try your method see if I can capture the amd overlay or not.
BlackWing1977
Nice tips👍
Yeah I remember it being very nice tool until I had my HDR monitor then all the issues came out.... :sick:
Yongkit
thanks it do work nicely. (y)
BlackWing1977
Nice tips👍
I actually tried another fix.. which is go into App, find Snipping Tool, Terminate, Repair, Reset and Uninstall. Then you try pressing PrtScrn again and it should still bring up that Snipping Tool despite that you uninstall the app, but no more Greyish Tint. I check from Google the issues seems to be there are 2 copies of Snipping Tool installed.. one from the app store and 1 which is the default Windows one... not sure how to verify this though, but it works.
There is a Screen Snipping App right now under Default App, I guess really got 2 version of apps and the Snipping Tools from Microsoft Store does not work well.
Yongkit
very nice and many thanks for sharing, will later try also
