cordless driver drill
charlieangel123
Makita and Bosch Professional (blue) about same quality. You choose one and stick with that brand for all your power tools.
Forget about Bosch consumer version (green). That one is quite cost effective, but is nowhere near as well made.
bosch have many versions le. confused
GSB185
GSB120
GSR185
DragonFire
I must say a chuck hammer is quite pointless. Get a SDS hammer bare tool only if you plan on masonry/brick/concrete drilling often. The expensive part is the battery system. The bare tool is usually quite cheap
DragonFire
If you like to DIY light projects, I'd get a cordless 12V system that is handy and has battery packs interchangeable with Dremel rotary tools (with a bit of modding)
For the occasional DIY wall drilling, I'd get (or borrow) a corded SDS hammer (they're cheap even for Bosch)
I'll say this. 18V system cordless drill drivers - especially the pro grade ones with a lot of metal parts - are fscking heavy. These are used if you need to do heavy work like drilling 10mm steel plate or driving bolts into hardwood.
I have a really powerful Hilti for that. I'd never use it for "light" DIY.
