Sorry, before what aircon and now changed to daikin 85?before aircon how much is your electricity use? No change in pattern?
I though is CCS , the pipeline go outdoor main doorYes outside then to toilet.
Why?
My 2 room got 2 ac sleeve. So 1 fcu each
Very low consumption only...what is the bill before you had the aircon? Or never tried that before?
Previously also at my old flat with the same usage and equipments i only pay about 200 max per mth.Anyway, your initial power used is rather high, due to the lack of current limiter.after midnight; it seems normal to me that every hour it uses 0.75kW of electricity. This is within my own estimates as long as temp doesn’t go crazy.
it could be due to showering and hot air or other factors not known
Panasonic compressor does not have current limiter? I can't find it in instructions manual. Anyways so should I take the mkm75vvmg or mkm85vvmg? Based on my new 12k+9k+9k all 3 turned on usage with 25 deg.Anyway, your initial power used is rather high, due to the lack of current limiter.after midnight; it seems normal to me that every hour it uses 0.75kW of electricity. This is within my own estimates as long as temp doesn’t go crazy.
75 = 7.5kw x 3412 = 25k btu vs 8.5 x 3412 = 29k btu, lol more or less like the starmex system 3 28VG.Panasonic compressor does not have current limiter? I can't find it in instructions manual. Anyways so should I take the mkm75vvmg or mkm85vvmg? Based on my new 12k+9k+9k all 3 turned on usage with 25 deg.
Chest freezer. My plan is to power on few hr a day is enough and is way more efficient then the normal fridge.Actually the fridge is quite efficient. Especially the inverter models.
the guzzlers are oven, Aircon, storage heaters left on, kettle flask left on, gaming rigs, induction cookers.
Fans, lights, washing machine with cold water consumes not much
Gaming pc 1200w PSU for rtx 4090Chest freezer. My plan is to power on few hr a day is enough uand is way more efficient then the normal fridge.
My guzzler is oven and storage heater
Induction cooker can combined with thermal cooker and pc with mini pc
This is a misconception. While a compressor with a low capacity will have a lower initial power, it will require a longer duration to cool the room to the same temperature, the total power consumption will be far higher when it had to operate at 100% load. The current it consumed has to be maintained higher for longer duration due to the 100% load and the efficiency falls as the result.
My floor plan 25 deg fan speed 2. 12 to 18hours a day. 200 to 331 kwh on avg for every month. Wonder if 12k+9k+9k a mkm75vvmg is sufficient for cooling and efficient for electricity. As my current 9k+9k+9k and cu-4xu33ybz is guzzling electricity.
But the rated btu for 75 is not 25kbtu.75 = 7.5kw x 3412 = 25k btu vs 8.5 x 3412 = 29k btu, lol more or less like the starmex system 3 28VG.
I guess you go for 75VVMG for more energy saving
daikin specs here
https://www.daikin.com.sg/resources/ck/files/catalogue/Q210202B-DAI R32 Residential Catalogue-Web version.pdf
75 normal rate 1.22kw vs 85 normal rate 1.71kw/h
It is 20k vs 85 25kBut the rated btu for 75 is not 25kbtu.
So meaning to say 85 would be better in terms of cooling efficiency and energy savings compared to 75?Anyway, I recheck the technical spec, you are right to say this. The difference of higher power use is not very obvious or they are considered very similar for different condenser capacity.
Having a bigger condenser is still better as long as the room is well sealed and the sizing is correct.
Ok...i think better play safe... dont want to givr trouble to gaincity or daikin...just take 85.
But is think the power draw could be due to other factors.
your 0.75kW power draw indicates it is providing 4.0kW +/- 13.6K of cooling. Normally it would need 3.5+3.7+4.5 or 11.7K BTU (50%) to maintain temperature
do you have a computer running in one of the rooms?
Hopefully everything can resolve on that day.
Update:Hi all, may i know what is the power consumption for a 9k + 12k fancoil with 4H33VG compressor running at 24c low fan speed?
Just change my aircon 1 month ago, realise today from sp app that the power consumption increased a lot compared to when just installed.
Any kind soul can help to explain?
