Air conditioning - Any recommendations please?? - Part 2
Sherra
If my floor plan is like this..
I will be removing the door at the master bed room, and then putting a door at the living room to the room corridors..
Going to put a aircon in the living room, master bedroom and bedroom 2.
WHat will be recommended aircon configuration and model to go for?
Edit: added color coded area for where the 3 aircons air will be circulated
obichacha
starmex system 3 or 4.
13 master bedroom
10 common
18 living / dining
007Mi6
Yes because it comes at 100%power. If u want to limit it then must ask contractor but also risk voiding warranty. Unless it’s done by panasonic themselves.
In NEA terms, 100% is the rated cooling. For Panasonic 4XU33YBZ, it is 7.0kW or 23.8K BTU cooling capacity.
As someone mentioned earlier, the most efficient cooling is between 40%-70%. Which translate to 2.8kW to 4.9kW or 9.5K to 16.7K BTU.
obichacha
Here you go for more accurate setup with every room FCU
ray12323
Hi All,
My installation of ME Starmex System 4 installation is tomorrow from Harvey Norman. The installation contractor is *Easycool Aircon Servicing*. Please advise is it worth buying the extended warrant from HN? Is it also good to have yearly service plan with service contractors or do adhoc services as and when needed.
Is it good to do a regular service such as quarterly or half-yearly?
Thanks for advise.
Hi there, I also going to install the ME Starmex system 4 from Harvey Norman next Monday. May I check how's their workmanship? everything looks good? did you upgrade your copper wire to the swg21?
For mine, I have to install the drain pump for the living room aircon as it will be lower than the drain pipe that runs from all the other room.
Chevalier
Attached is the floor plan
Lower floor:
Areas tagged as balcony & living rm: they will be merged into one massive dining area
Areas tagged as study & dining rm : the wall will be torn down and the large space will be living room and study\reading lounge.
Upper floors: no change: bedrooms remain as is.
Hence my ID proposed a dual compressor system, 3 units downstairs and 3 upstairs.
Preferably ME, just not sure what BTU should be used.
Usage downstairs could be hheavy when hosting gatherings or game nights.
Would appreciate your thoughts folks!
obichacha
nowadays Harvey Norman got their own aircon installer team or sub to others?
Why need to install drain pump?
below have 2 options, which one do you prefer ?
obichacha
Lower floor:
Upper floor you may consider 3H28 (13+10+10)
Lower floor , get 4H33 (living 18k , dining 13 and study room 10)
Chevalier
thanks!
Traditionally for maisonette, the condensors are placed in the balcony, however I have neighbours in the same block who have placed their two condensors outside their unit. I'd like to do the same. anything i should look out for?
obichacha
thanks!
Hanging on outside balcony parapet wall ?
Not too sure. Can check with the installer
obichacha
im thinking to place the two condensers on the parapet outside bedroom 3 and study room, thats what i've seen the neighbours do
if the window is non accessible, don’t think can lift out the condenser.
You can install then just do quietly 😂
Chevalier
oh, window is accessible, in fact the condenser likely to just be outside the window like shown. My future neighbours house in picture for ref
ray12323
It subcon to others.
Need to install drain pump cause the drainage route is via the room behind the living room aircon. no other way to route it already. and cause on top of the wall is beam so cannot drill hole. that's why the aircon need to be placed lower than the rest of the aircon in the rooms. the drainage route is along the beam.
mark lim
Down
Lower floor:
. Since you are hosting and you need the cooling power. Else not much use, if it takes 1hr plus to cool the whole place down. Best is to take 18k for living and 18k dining. 4H33. X2 units One set for the living and master with compressor at the balcony and one Set for the dining and 2 bedrooms, compressor outside bedroom3. This way you also keep the pipe runs short. But not sure if HDB allows for some length of pipe runs outside bedroom3 to the dining area.
