Short summary of VQ recontract to 3Gbps plan.
1) Price wise. it's a no brainer. Just do it.
2) Process wise. Just login with your singpass to VQ and do a recontract. Less that probably 5 clicks.
3) if you are on static ip. they will followup with a email to ask if you want to continue. If your reply yes. you will receive another email confirming. It's $4.04 per month
On the day of service switch over. dude will show up with new ONT. just replace. everything else stays the same.
My thoughs
For 3Gbps plan. Just get a 2.5G capable AX wifi router. Preferred to also have a 2.5G lan port to optimise bandwidth usage
iperf3 test to a 10G host max out at 2.82Gbps both up and down.
iperf3 test from a 2.5G ethernet port max out at 2.35Gbps both up and down
iperf3 test from iphone and macbook air on AX. speed is exactly the same as 1gbps connection.
Will entertain any intelligent and logical questions.
Edit/Add on:
1) the power adaptor is the same as the one for the small black box. But i swap mine for a new one
2) installer also gave a a CAT6E cable. Not taken out of packaging yet. no use to me
3) since he gave ethernet cable. I ask for new optical cable whch he obliged
all in pleasant and fuss free switchover.
My thoughs
Edit/Add on:
