diopter
pretty sure with amazon prime day, its cheaper to build yourself. Heres what i made a few days ago with the big deals day:
$1486 total
$835 without GPU, all the parts are from amazon.
CPU: AMD RYZEN 5 7600x $180
CPU Cooler: Thermalright Peerless Assassin 120SE $43
Motherboard: GIGABYTE B650 Eagle Ax $227
RAM:LEXAR THOR 32GB 5600Mhz CL36 $92
Storage: 1TB Crucial P3 $55
PSU: Thermaltake GF1 850W $107
Case: Montech Air 903 Max $100
Extra fans: 6x Thermalright PWM TL-C12C-S ARGB $32
GPU: Powercolour 7800xt $650 Thetechyard
Thanks, will try to compare with Amazon.
deepblue_82
ignies
For 7800xt what the min PSU watt needed?
minimum recommended is 700W based on AMD reference specs.
however, some board partners recommend 750-800W, do check with the specific card you are getting.
some people say they can get away with 600-650W, but best play safe
NightRaven49
I was planning to build my own rig and after comparing the price with builders like aftershock and invader, i found the price is actually cheaper.
Should i go with Invaderpc? Please advice?
prebuilts are generally very price competitive, though of course some corners would be cut to achieve those prices. usually these cuts come in the form of lower grade parts of everything besides the cpu and gpu, which dont necessarily take away from the performance overall but does mean u are not getting the best parts. if u just want a pc, prebuilts are fine but i do encourage diy for the experience. u can also find a sample build in the first post.
Any specific models of mini pc for my wife to recommend?
I've only built mATX or ATX builts, so have no experience with small PCs haha
https://forums.hardwarezone.com.sg/threads/mini-pcs-2023-any-good.6859514/
manufacturer recommended values usually include quite a bit of headroom. the 7800xt generally pulls about the same if not slightly less power than a 2080ti, which work fine on 650w. amd recommended 700w with a 7950x, so for most users with lower power cpus 650w should be enough.
352812
Hey guys, looking into building a rig and wondering if these will work or am I better off getting a prebuilt. Most intensive usage is probably going to be maya and after effects. Prices are chapalang from various sites including amazon so might be different already.
CPU - Ryzen 7 7800X3D ($565)
Cooler - Thermalright Peerless Assassin 120 ($43)
Mobo - Gigabyte B650 AORUS ELITE AX ($284)
RAM - Lexar Ares 32GB ($134)
SSD - Crucial P3 1TB ($55)
GPU - PNY VERTO GeForce RTX 4060 Ti 16GB ($688)
Case - Montech Air 903 Max ($97)
PSU - Corsair RM1000x 1000W 80+ ($184)
deepblue_82
if u are working and not gaming.. should not be looking at the x3d cpu...
i think 12gen intel is better...
352812
Gonna be doing both since is my home pc, I don't play much AAA though. Is X3D worse for work stuff? My friend who also does 3D has another AMD CPU (5 something) and it supposedly works well for him so I wanted to try out.
deepblue_82
the 3d is a gaming processor so its better to look at 7600x or higher what not but i think the prime day sale is gone on that...
ur friend's am5
deepblue_82
FOr PSU i looking to purchase locally. Looking at MSI mag a750gl or corsair rm750e or adata core reactor 750w. those are okay right?
@NightRaven49 got say
it is in their price list pdf, page 2 1st and 2nd column from the right labelled power supply. the core reactor ii ve is listed for 129 (under the thermalright tg-750w), while the cooler master v650 v2 gold is listed as the cm v650-650w v2 white 80+ gold (under the cm v sfx platinum 1100w) for 119 in their currently latest 5 oct pdf.
iceblendedchoc
it depends on what work you do, video conversion/editing, live streaming, adobe photoshop or running AI. If heavy duty, X3D will affect , if it is just light work like spreadsheets, X3D not going to affect it.
diopter
$1486 total
Bro how u get the cpu so cheap, i search in amazon and the cheapest i found is $445 and RYZEN 5 7600 is $285.
Can share the link?
deepblue_82
Gotcha (y) looking into i7 12700 too, is KF ok or do I want the igpu?
most ppl leave the igpu as a backup or a troubleshooting, would depend on your self.
KF unless u are overclocking there is no use.
and yes 12gen is upgrade limited
unless u can wait for the new intel gen around the bend....
but at the moment it would be better going for AMD am5
