- Sep 16, 2018
Hmm then if I bridge port 5, can I connect their provided AP (the arcadyan nonsense) to another unbridged port and still get internet access since the ONR itself is also assigned another IPV4 address? Theoretically it sounds like it should work
This was exactly my plan and I did not plan to bridge another LAN port at all, since this was the experiences from those early users who were able to bridge the Singtel ONR with older FW versions (same behaviour as the GPON ONR bridging case from Singtel 2Gbps and WC 2.5Gbps users).
But no idea why it is not working now. That is why I took the risk and bridged LAN 2.
You can try it to see if it works for you or not.
Hmm.. my case I bridge port 5 , only port 5 working , other ports no Internet at all.. new singtel tv box no need to use seperate VLAN, can even use WiFi according to technician.
Interestingly today I tried to bridge Singtel ZTE F8648P ONR Port 5 only and it works fine, as you mentioned, only port 5 working, other LAN ports got no internet at all (even though Singtel ONR still got a vliad IPv4 address).
BTW, I have cancelled my Singtel TV service as it is really not used much in the past three years.
Great to hear that , it is game changer for Singtel if the bridge mode remain working well. Managed to maintain 7 to 8Gbps consistently throughout these few weeks.
The rest of ports is mainly for TV I believe. I plug in the Singtel TV it work fine concurrently with Boardband.
My own experiences with ZTE F8648P ONR -- with the 10Gbe LAN5 port bridged.
1) The router connected to the bridged ONR 10G LAN ports --> internet is working, native IPv6 is working.
2) The unbridged ONR ports (quad 1Gbe ports, LAN1/2/3/4) no longer have Internet access. This is different from last time. This may be specific to Singtel 5Gbps/10Gbps plan users using ZTE F8648P XGS-PON ONR.
3) I can still bridge one more 1G port and that does work. Tested with LAN 2 and Asus RT-AX86U and it was working fine. But no native IPv6 --> I can only configure Singtel 6rd to get IPv6.
