- Sep 16, 2018
That's just sad. Thank you for the insight. Any response from Asus? Appears to be just a driver problem. Based on the issues you heard with the Asus adapter - is it reports on the adapter not giving the full speed, and having some speed degradation?
I've only seen an "all-or-nothing" complaint where the user was stuck at 1Gbps with that adapter.
Unfortunately among the recommended list I'll be looking to shell out at least $200 for the Intel x4 one. Also given the position of the empty PCI-E slot at the bottom the airflow is not going to be very good.
The issue reported in this forum are all about speed degradation for Marvell chipset based 10G NICs (PCI-E or TB3 version). Some users can resolve the issue by disabling Antivirus programs. Some users say re-installing Windows can sort out the issue. Some users are not able to sort out the issue.
You can try the work-around to see if it helps you or not (eg: remove 3rd party antivirus programs).
I think Asus has no capability to sort out the issue. Marvell is the one which can do the driver development.
Intel X540 NICs can be bought at about S$30 to S$50 from Taobao.
Intel X550 NICs can be bought at about S$100 to S$150 from Taobao.
