- Mar 31, 2001
5g router from shopee $240+thanks bro. chiu are da best!
how much chiu paid for 5g router? got below $150 one or not
Malaysia around $200. But it got problem Dunno go where service5G router all around $300, no matter if they are selling from Malaysia or Singapore
what model again? i go take a book5g router from shopee $240+
Read some bad reviews also,sian
Simi bad reviews?Read some bad reviews also,sian
What phone Chiu use?Been using smart phone plus sim card as moi home router . Last time can stream shows.. now stream Abit Abit lag need to load and play again. not smooth.
Mi phoneWhat phone Chiu use?
You click on the listing and read the bad reviews loSimi bad reviews?
I think more than 10gb.i see 5 minutes mewatch already 100 mbownself do evaluation how much data needed per day for you usual practice.
est. 10GB a day should be enough for youtube and online drama and surfing whole day
Yah I also saw. Better to buy once, cry once than cry many many timesYou click on the listing and read the bad reviews lo
Not necessary to have 5g in your opinion?Just my opinion. after having dabbled with 4G/5G routers and SIMs;
If I were to start over again. in terms of $ cost effectiveness.
I would buy the deco x50-4G wifi 6 ($250), and the $5 300GB Simba data-only plan. If I have not enough data, I'll just buy another $5 data-only plan.
Be happy with 4G, wifi 6 is more important, in terms of throughput.
Based on my last download test result:Not necessary to have 5g in your opinion?
MybfdRead some bad reviews also,sian
Ya I would choose to go with the deco 5g alsoJust my opinion. after having dabbled with 4G/5G routers and SIMs;
Yes, it'll work.is 5G really needed?
Thinking to get this https://www.dlink.com.sg/product/dwr-m955x-ax1500-4g-lte-wireless-mobile-router + Simba $5 plan, will this combo work well?
