- Sep 16, 2018
Thanks for all Bros advice. The ST tech came and solved the issue. He activated "forget my wifi" and turned off wifi on the android box and reset the android box and after that Singtel TV can work, He said the android box cannot work properly with Singtel TV when its wifi is turned on. He confirmed that if use 3rd party router, only LAN 4 port can work for Singtel TV.
I tried but my parents find it hard to navigate the smarter apps and like the Taiwanese dramas from Singtel TV. Parents are happy so my life is happy too haha.
Cannot use wifi. the wifi was the one causing the problem. Have to use LAN port 4 only.
Thanks a lot for the updates.
Conclusion:
Singtel Android TV box still needs VLAN ID 20, same as the existing Singtel TV Box.
You have to set up Singtel VLAN if you use ONT and your own router (eg: Asus).
If you use ONR or ONT plus Singtel issued router, SingTel ONR and/or SingTel issued router will handle VLAN for you. No need extra settings.
