Guys! You all got DIY clean your aircon blower ?
Jun Jun
Anyone got guide or tutorial video of dismantling and what to wash and what not to touch for Panasonic interverter nanoe X?
X premium? If 9k blower top have a few clip switches switch to unlock. Then unscrew the few screws from the aircon casing. Casing comes out, the sides got another screw have to remove before removing the blower. Blower inside also have screw. Design abit like daikin and starmex. That is from my observation when they took apart.
Jun Jun
Anyways any recommended aircon servicer who does jetwash at affordable rates with the right tools and correct handling?
Jun Jun
me using starmex, my future 2nd condenser, i was thinking midea or pana or starmex again
BTW midea all easy pro got version 2, so do take note
version 2 the alu fin and air flow gap will be much larger more then version 1 but not sure if sg sell or not
this is the 2nd gen aka version 2
Have. Sg alr selling. Gc can view.
ducky_88
Yes, Premium X. Thanks and appreciate you take the time to write this. Do you have a sample video that would really helps me a lot.
The_King
just did my first diy cleaning, my AC look clean but after spraying with ajax then wait 6min then spray 2nd time, and pressure wash the fin and blower, my FCU dont look dirty le (blower hardly any dirt, and fcu no dust stuck on it) but after washing i can feel it even colder then before
before washing
after washing
XcoVar
before washing
after washing
Got invest in a Karcher dry/wet vacuum to suck the pipes? Had it for years, really good investment.
vbhelper
before washing
after washing
looks satisfying. Do u dismantle the blower too?
a4973
no nv dismantle the blower. i wash with the FCU case on. then every 3 wash with casing on, the 4th wash will be without FCU case
So you are saying that the blower has never been dismantled for washing but just washing in place? How effective is washing in place? Thank you
The_King
not sure how effective . but it work for me and many here
pokipoki08
any sifus know the name of the non corrosive cleaning liquid for fan coil & radiator? thanks
edit : found it
ajax fabuloso, supersteam 301 or 306, comstar coil safe, use undiluted from spray bottle
gregory_choo
colder than before.
how can it be. aircon temperature is controlled by thermostate.
Downloader
As the thread is long running, I'm so overwhelmed not sure what to get for diy aircon service.
Can anyone advise what is the current recommended power jet and wet/dry vacuum to buy now and if possible where best to buy?
For power jet, I read that it can be very loud and thus brushless motor is better but not sure what brand and model and if have attachments dedicated for fcu and cmu washing, especially for the back of the fins, hard to reach angle, etc.
As these equipments can be bulky, I'm wondering if should get one for multiple uses to make full use of them e.g. car wash, sofa/fabric, steam function (got such thing?)
On the flip side, I've also saw some using just a hose attachment connected to tap for washing and bottle hacks attached to drainange so that can use normal vacuum but not sure if they are powerful enough.
Is there a list of essentials and recommendation that I may have missed?
TIA!
0768086
colder than before.
It feels colder because before washing, desired temperature setting cannot be achieve and the compressor is running non stop trying to achieve set temperature. This is due to choked coil restricting air movement through it.
The coil is so super cold but the fan is not moving air flow through the coil fast enough and push the cold air into the room. This cause high electrical usage and desired temperature cannot be achieved.
