EV or ICE car
keenklee
Can you drive for 300KM without resting? I use the resting time to charge.
The point I am trying to drive is you don't need excessive range to drive an EV at Malaysia.
Typical range in 400-500 km are good enough.
Yes 800km range is impressive for your PHEV
IMHO.
No issue driving my present car for 300km because the car computer assisted me for the following
a) maintain speed
b) maintain safe distance from the front car
c) keep in lane
800km is in Malaysia. In Singapore, estimate about 1000km.
HMAN
Warranty cover below 80% right? Even if drop to 90%, you will already suffer loss of range.
Battery warranty coverage up to 8 years or mileage between 160-200K km. If battery degradation reached 70%, battery swap will be provided.
Based on charge cycle life expectation of 1500 cycles. Hardly one will run into problem .
Read EV cars history at USA forums to get a better understanding.
satire85
Ya out of 1500 cycles of charging, you prob experience degradation for 1000 cycles.
Are you a BYD salesman? You seem very blinded and bias.
Don’t mislead people in this forum on benefits of EV when you don’t know how batteries work.
The only way for EV to be mass market is when battery swapping is mainstream. If you keep using the same battery you will suffer loss of range and performance.
weng0202
For now choose ICE bah, wait for EV to become more mature and stable first. By then, the mileage will be higher and battery will be less expensive to change.
testerjp
Suppose you charge once every 3 days.
And the battery has 1000 cycles before it degrade to below 80 pct real capacity. EV is not like HP which you charge daily.
That's like more than 8 years.
If I'm not wrong EV Road tax is higher, but the savings from electricity should be still higher.
drkcynic
My EV 2+ years old only lost less than 4% range. I won't bother with gpgt since you apparently "knows how battery works", then up to you.
Performance, no clue, never measure, I still overtake effortlessly.
Battery swapping become mainstream on EVs? Don't joke please.
hachi
Never say never... One fine day if charging from 20-80% within 10mins. Happy to make the change.
Like to drive to Malaysia until ipoh...
HMAN
Go read more EV battery research reports, plenty of them on YouTube.
EV battery is having much higher charge rate in 3C to 4.5C versus your phone battery with 1-2C .
1500 is full charge cycle and it is a conservative figures. You won't get high degradation unless you do daily charge from 80% to 100%
EV manufacturers do provide guidance to maintain battery health based on battery type.
LFP battery can be charged to 100% frequently versus NCM ( can be charged at higher rate) but can't be charged frequently to 100% others risk excessive degradation.
I just based on my daily work dealing with consumer electronics lithium ion battery ( real products) definitely don't know indepth over EV battery.
Nuclear Boy
ICE.
By the time your COE expire in 2035(?), then the EV charging network would be more fleshed out here.
EVs make complete sense here, if not for the current lacking of charging infrastructure. And hopefully battery chemistry gets more magical in the near future, so there's less need for frequent plugging in.
elimmel
Another 5-6 years to think about it.
But cost will be main factor be it ICE or EV.
die
EV is just front load pollute...and its even more toxic with the process of extracting precious metals
to be honest
ev is front and back and pray there is no middle part haha
why pray no middle part because if caught fire and bbq ...
one shot can release dont know how many years of pollution
they should ev all the commercial vech first since most commercial vech always on the road one ...
die
ICE.
3-4 years in ev mileage will drop also
die
"Technically" better, to me EV main advantage is can blow aircon while waiting without turning on engine :s13:
The key drawback IMO is risk of fire but many EV advocates will say it's a very low risk. Ultimately, you should just go test drive a few personally and see which you like. If you don't like a particular car, doesn't matter if the rest of the world think it's the best.
can sleep inside no need scare kanna poison haha
anyway check on repair cost too ...
my boss tesla backside kanna kiss by ppl ....
the repair cost is WOW haha
they say the backside is a whole piece by itself
if wanna replace have to send in and replace the whole thing :ROFLMAO:
Nuclear Boy
Good thing of using in SG is the short distances, meaning most people wouldn't have to charge their battery very often, like on a daily basis. Maybe can last slightly longer.
