I did.did u watch the video at all? he states very clearly that rebar was enabled for all his results, which does exist on certain 300 series mobos like the one he used. rebar definitely had an effect, but it was still not enough to save the b580 from falling apart in certain scenarios.
While rebar was enabled, the CPU used is not in the specific* list of supported CPUs as per system requirements. SPECIFIC.
Duh. Reviewer should state so upfront to be fair.
Please be fair if you are going to be an impartial "professional" reviewer.
He did not follow the basic system requirements and then he says the performance was not good in that specific setup. What is his point? Nothing?
* Intel 10th gen or later. Ryzen 3000 or later.
