1) Yes, the wireless speed and wired device connected to the Singtel AX5400 device will be below 1Gbps as the WAN/LAN ports are only 1Gbps.
2) Singtel ONR itself is the main router of your home network. It has one 10G LAN port, so you do not need to get extra router if you have a wired device with 5Gbe or 10Gbe network adapter.
https://forums.hardwarezone.com.sg/threads/5gbe-and-beyond-ethernet-adapters.7068236
3) For wireless, it is in general not possible to hit above 5Gbps. Usually you get less than 3Gbps at 3m distancde, even if you have a very good WiFi 7 router. Singtel provides two routers if you plan to get from Singtel.
a) HB810 --> 10G capble, WiFi 7 BE22000, at S$16.80 x 24 month = S$403.20.
https://www.singtel.com/personal/products-services/broadband/eform/wifi7
https://www.tp-link.com/sg/service-provider/wifi-router/hb810/
https://www.singtel.com/personal/support/broadband/routers-ont/TPLink-HB810-WIFI7
b) HB611-SGST --> 2.5G capable, WiFi 7 BE11000 (lucky ones may get this for free).
https://www.tp-link.com/sg/service-provider/wifi-router/hb611-sgst/
https://www.singtel.com/personal/support/broadband/routers-ont/singtel-wifi-7-router-hb611-sgst
4) You can also buy your own WiFi 7 router as well. I got one TP-Link Archer BE805 from an M1 user at S$300 recently.
https://forums.hardwarezone.com.sg/...-7-routers-without-6ghz-band-support.6905228/
Just did a check, seems like i am still using the legacy ONT from Singtel. Nokia G-240G-E.
2) The 10G Lan port would suit my needs for my wired device but not for the wireless devices. Unless i convert my wired device to wireless as well, and just hook up a modem to the 10G port on the ONR.
3) Yup i am aware that i will not hit anywhere near 5GBps and i am not expecting that, but i would at least like to have hardware that supports 5gbps, and not be hardware limited.
4) Yup seems like that is the only option, to get a 10gbps/5gbps router.
In light of needing to get a new router anyway, and i am thinking to just get a 10gbps one instead of an older model, what are your thoughts on going Simba 10gbps for the same price?
