robie_aibo
- Feb 28, 2008
If I were you, I will try to find oem rings, or just buy another set of the lens protector and put on a case that does not cover the cameras.
$200 for those glued on rings isn't worth it.
I guess so... my wife's set I will leave it as it is as she doesn't want her phone to be hospitalized. Now all phones going to service crntres have to be reset even though Samsung has this repair maintenance feature. I was told something happened that's why they want all customers to backup and reset their phones.Need to be careful. I almost did the same thing as you. You have to make sure when you remove the ring, you "lever" against the outer camera protector. I suspect what you did was your screwdriver went a bit too deep and end up "levering" up against the inner camera ring
