Anyone here staying in 2 room BTO?
Should we move it to HomeSeekers and HomeMakers?
  • Total voters
    49
  • Poll closed .
wongminmin
I just checked with Shopee's "DFS LED Light Local Supplier".
$65 per trip. Plus $25 (depending on model) per light too.
wongminmin
how do you mount the holder? I don't have a drill nor familiar with these, so need someone else to do it.
Disclaimer: this is just my own planning, to save costs. lol
no need to drill... just clip on. But u need to know how to connect wire.
this holder cost about $3~4 each. 7 x $4 = $28.... e27 light bulb $1~$10 each
then for downlight, u can also use clip on like this (no need drill)
https://shopee.sg/Slim-Square-Round...-Year-Local-Warranty)-i.290668895.4245484087?
Techno Pride
BED queen size??
Any gaming table?
Aircon system 1 or 2?
TV 55 inch?
Bed queen size, but maybe at a later date.
L shaped table 180cm x 120cm.
Aircon System 2, later date.
No TV. Maybe bigger computer LCD and attach both laptop and Switch OLED to it.
Techno Pride
after defect check.
install lights and instant water heater..
1 bed and 1 fan.
then slowly do.
can move in already :D
Already bought a KDK P40US. Have used the Panasonic F407YS (similar/same model) at my current home, but the Panasonic didn't have white and I wanted the round KDK base too.
The_King
wah.. dont frighten me.. mine is half rental block..
it normal for police to come often, there urine smell, goods stack high high outside their unit, fighting, shouting it all normal, thing all anyhow throw, anyhow paint etc.....
i explore often so it normal, here a rental block. i take this one cause special
EDMW-Hates-Me
I think it was an empty unit. See the blue tape on the fridge.
Maybe the property agent brought in his own furnishings to beautify the place. Will have additional charge for this.
Doesn't look good at all. At most can avoid people from reporting you for not staying. Anyway, you see poor places, some people can really cook from that setting, or even worse ones.
Mr.Canberra
Rental blocks usually have police cases every now and then.
Suicide, domestic violence, manslaughter, fights, drugs related, vandalism, etc. NOT UNCOMMON!
Some households really unable to break the viscious cycle. One generation after another still have the same problems. Very tragic.
Mr.Canberra
every rental block i always spot at least 2 fridge, 2 cupboard outside the flat
Cannot blame them. Mostly are only 1 room flats. Not uncommon to have a family of 4 or more staying in one of such units.
But the rent is very cheap if you are a super low income household and eligible. I think around $27.00/mth excluding S&CC and town council fees.
However the wait can be quite long unless your case is very special then social services may expedite your request.
The_King
Cannot blame them. Mostly are only 1 room flats. Not uncommon to have a family of 4 or more staying in one such units.
But the rent is very cheap if you are a super low income household. I think around $27.00/mth excluding S&CC.
now new bto mix with rental, if can avoid just avoid.
pigpigoink
when u guys paint(diy or paid), is the bomb shelter aka storeroom painted as well?
The_King
for me yes, i paint everywhere, inside DB also paint, the small wall in between metal gate and main door also paint, the toilet partition , the partition metal part all paint
