wongminmin
- Nov 10, 2014
I just checked with Shopee's "DFS LED Light Local Supplier".
$65 per trip. Plus $25 (depending on model) per light too.
Expectations (the floor plan) vs reality (my measurements in blue)
Disclaimer: this is just my own planning, to save costs. lolhow do you mount the holder? I don't have a drill nor familiar with these, so need someone else to do it.
BED queen size??
Any gaming table?
Aircon system 1 or 2?
TV 55 inch?
Haha just for cooking instant noodles maybethis kitchen so simple. lol
TOP in 2018
after defect check.
install lights and instant water heater..
1 bed and 1 fan.
then slowly do.
can move in already![]()
we are luckyWa...2 rooms now so ex.
it normal for police to come often, there urine smell, goods stack high high outside their unit, fighting, shouting it all normal, thing all anyhow throw, anyhow paint etc.....wah.. dont frighten me.. mine is half rental block..
Doesn't look good at all. At most can avoid people from reporting you for not staying. Anyway, you see poor places, some people can really cook from that setting, or even worse ones.I think it was an empty unit. See the blue tape on the fridge.
Maybe the property agent brought in his own furnishings to beautify the place. Will have additional charge for this.
that why i bow down to themDoesn't look good at all. At most can avoid people from reporting you for not staying. Anyway, you see poor places, some people can really cook from that setting, or even worse ones.
i explore often so it normal, here a rental block. i take this one cause special
every rental block i always spot at least 2 fridge, 2 cupboard outside the flatRental blocks usually have police cases every now and then.
Suicide, domestic violence, manslaughter, fights, drugs related, etc. NOT UNCOMMON!
now new bto mix with rental, if can avoid just avoid.Cannot blame them. Mostly are only 1 room flats. Not uncommon to have a family of 4 or more staying in one such units.
But the rent is very cheap if you are a super low income household. I think around $27.00/mth excluding S&CC.
have but the supermarket happening once a while due to rental flat nearbyWill have separate stack.
for me yes, i paint everywhere, inside DB also paint, the small wall in between metal gate and main door also paint, the toilet partition , the partition metal part all paintwhen u guys paint(diy or paid), is the bomb shelter aka storeroom painted as well?
