For the first case, if you happen to have two ports in the patch panel that connects to the router location, you can then connect one of the router LAN ports back to the patch panel - and add a network switch to wire up the rest of the patch panel ports to the other rooms.Sorry, i think this has been asked previously but i couldnt find it.
If TP connect to ONT only and then ONT connect to patch panel, then to router. Is it we cannot use the lan ports in the other rooms?
If TP connect to ONT and ONT connect to router directly, we can then use the lan ports in other rooms.
This was what i read somewhere, is it correct?
Thanks.
