kun1he2
Wow, that's a lot of network points!
Is there any possibility that there are two LAN points per room?
Noticed that there's D01 and D02 at the top-left too - which is odd.
Meanwhile, yes, your understanding is correct.
My main Asus BT10 router is also in my DB cabinet with wired connection via patch panel to secondary BT10 mesh node in study room.
marxace
yes, there are 2 points in living room, 2 in each bedroom X 2, 3 points in MBR and 1 in study room and 2 in the DB box (D01 and D02) which i also feel weird why is it in the DB box.. Total 12 LAN points.
kun1he2
Wow, impressive.
Since you have two points going to the living room, say D10 and D11, D10 can connect to the ONT in DB, linked to the router WAN port in living room.
D11 in living room then connects to the router LAN port, linked to D11 in the DB.
D11 in DB then connects to another piece of equipment, i.e. network switch
Thereafter, wire up whichever points to the network switch in the DB.
weiess
Just received my first bill.
Can check the router be805 $16/mth extra is charged to the bill?
M1 app. HomePac account.
Plan tab > Device Installment > Router add-ons
u can see the 24months installment plan breakdown, if any
SleepyBear
Thanks! Managed to saw it at $0.00
But M1 still charged me. gotta ask them to rectify the issue. ._.
Dorkable
I went to M1 Shop today to apply for their 3Gbps broadband package based on their current switch-in promo price at $30.90/mth with free TP-Link BE230 router. Their staff did take a screenshot of our latest Singtel bill as part of their protocol to justify for the promo.
Understand that some of you here recently shared that M1's Huawei ONT runs rather hot. Thus, I asked the staff if their ONT is the white Huawei model, and she confirmed that it is. So when the installation is done, I will monitor to see if a cooling fan platform is needed in my case 🙂
Dorkable
For those of you using TP-Link BE230 router, may I know if it gets hot like the Huawei ONT? Coz I am wondering if I should buy a double level rack with cooler fans to house both the ONT and router. Thanks! 🙂
rapcon
Isit still alot area not fibre ready for the 3gbps and above? I input my postal code and it said my area is not ready.
ceecookie
Had to temporarily withdraw my asus BE92 from duty today... today crashed so many time until i fed up and swapped back to my older Wifi6 setup. Before that, I notice the uptime was no more than a few days before it would crash.
Now i've factory reset the BE92 and upgraded firmware to 3.0.0.6.102_37548 (previously was 37200 or 37300 something). Will monitor it running isolated to see if its stable enough.
After some monitoring - i found out it was one (couldnt identify what) 2.4Ghz wifi client in my house that keep triggering MLO error in the RT-BE9U router every few minutes. Eventually after a few hours, this would trigger a crash of the router.
I blacklisted the MAC ID of that client (extracted from router logs) so it couldnt connect anymore. After that, the crashes all stopped liao.
kun1he2
Curious, what happens when the router crashes? All wifi and wired connections break?
And require hard power cycling of the router to recover?
xonix
Probably compatibility issue. Many IoT devices or older devices will face problem with WiFi 6 & newer routers. Just create an IoT guest network with wifi 6 or 7 disabled and connect such devices to this signal instead.
ykeen
Moderator
Moderator
So what happened to that (IOT?) blacklisted client ? Which of your device is not working now so you connect to a new IoT 2.4G SSID?
Dorkable
I just saw on Facebook that M1 is having a flash promo for new sign-ups:
3Gbps bundle $29.50/mth
6Gbps bundle $34.90/mth
But I just signed up yesterday for the exact same 3Gbps bundle for $30.90/mth 😑
Griggs
Can try call in and ask whether they can offer you new rate since you just signed up yesterday
ceecookie
Router crashing is same effect as doing manual reboot thru admin portal. Will lose wifi and network connection for about 3-4 mins while the router boots up. No need to do any power cycling.
I am unable to locate and identify the culprit device. It must be an old wifi-enabled IOT device around my house which I dun use anymore. :)
Prinsloo
Hi can I check if I can port over to M1 if my SingTel broadband is due but my SingTel TV still in contract?
TanKianW
Stability > Speed. A good wireless AP is not just simply about speed. In fact, speed upgrade is the easy part as tech advances. A competent AP provides the widest compatibility with devices, stability and consistency, maintain and manage wifi connections with clients (knowing when to drop), especially (even) in a challenging noisy environment.
Some higher end APs (mainly enterprise grade) support (background) active scanning of rogue devices or APs, load-balancing, auto blacklisting any devices or banning persisting connections that is flooding the wireless network which tries to bring the whole network to a halt. You can check if your AP support some form of dropping/banning devices with persistent failed or intermittent connection. Normally this can be achieve with adjusting a certain threshold or client management interface.​
Yes you can. But take note you may lose the bundle benefits in the future.
You may need to check with Singtel whether they will issue you a new ONR or not.
Existing FTP Port --> Singtel ONR (no internet access) --> Singtel TV
Another FTP Port --> M1 ONT --> Router
