Recommendation for portable Air Cooler ..
helloicanseeu
It’s honestly better than nothing, those portable water cooler fans
they dont work if the humidity is too high, those warm nites ... only ac work
when the humidity isnt that bad, those mist fans have some effect, i agree
deathan9el
Honorary Mentor
I am searching for one...
Just need to pour water in the tray n switch on will do.
can try look see at NTUC Finest or Extra or Giant, they have a section for this before but not that many models lahh ..
not sure if they still have it or not :o
Foetid
luckybigcat
Evaporative cooler aka marsh cooler isn't as effective as advertised in humid countries like sg. And the high humidity promotes mold growth. The evaporative panels might be paper so take care to check that. Because of its design/ tech, it's inherently loud
helloicanseeu
Just for one room only...
Cos the air con now blow normal air.
Is it no gas???
ac blow normal air??? something is wrong liao, call techinician
pipe can leak if very old, but its more oft used as an excuse by unscupulous ac technicians to squeeze more marnee out of unknowning and trusting home owners,
i did saw the ac man use a portable welder to weld some pipes in the old rental apartment i had years ago,
more often the compressor just gives way if the environment air is dusty/dirty (if u stay near a road), or the usage is too heavy
menthol28
Usually portable AC is the opposite, compressor will give out water. Those that require U to pour water in to cool is a normal fan
jeffprobst
Just to clarify, TS is looking for a portable aircon, not an air-cooler, right?
From what TS mentioned, it seems there is an aircon but it’s only blowing normal air. Maybe the aircon just needs servicing? Could be an issue of poor maintenance, like never washing the filters or cleaning the unit. If that’s the case, TS might not need to bother getting a new aircon at all.
If TS really wants a new aircon, does that mean replacing every existing unit? or if only need one unit, replace that unit or get those old window units?
For portable aircons, remember you need a venting hose (trucking) to push the hot air outsince there’s no aircon that works without expelling hot air. Portable units are also noisy and take up room space.
As for air-coolers, that’s probably my last recommendation. Unless TS is staying in a small space like a utility room, where it might still do okay without aircon. But air-coolers come with their own issues like water leakage, noise, and space constraints.
Lchlch
Shd be air cooler
Lchlch
I think I tupelo wrongly, should be portable air cooler.
