articland05
- May 2, 2015
then the hot exhaust air go where?Exactly, that's why I wanted to get one without those tube blowing out hot exhausted air.
u inhale the exhaust ah? lol
All aircon have hot exhaustExactly, that's why I wanted to get one without those tube blowing out hot exhausted air.
got wash aircon? service aircon?Just for one room only...
Cos the air con now blow normal air.
Is it no gas???
Those portable one dnt hv .then the hot exhaust air go where?
Last 2 years back.got wash aircon? service aircon?
very noisy for portable aircon - second hand ones -Any recommendations?
they dont work if the humidity is too high, those warm nites ... only ac workIt’s honestly better than nothing, those portable water cooler fans
can try look see at NTUC Finest or Extra or Giant, they have a section for this before but not that many models lahh ..I am searching for one...
Just need to pour water in the tray n switch on will do.
have ma...which one dun hav?Those portable one dnt hv .
can think of 2 reasons - aircon dirty - how to know - visual inspection, wash the filter, and wash the aircon finsJust for one room only...
Is it no gas???
ac blow normal air??? something is wrong liao, call techinicianJust for one room only...
Is it no gas???
Usually portable AC is the opposite, compressor will give out water. Those that require U to pour water in to cool is a normal fanI am searching for one...
its the last solution ... its still a solutionThe worst thing about portable alAC is it's consumption of electricity, it's almost double of a system 2 inverter
Shd be air coolerJust to clarify, TS is looking for a portable aircon, not an air-cooler, right?
From what TS mentioned, it seems there is an aircon but it’s only blowing normal air. Maybe the aircon just needs servicing? Could be an issue of poor maintenance, like never washing the filters or cleaning the unit. If that’s the case, TS might not need to bother getting a new aircon at all.
If TS really wants a new aircon, does that mean replacing every existing unit? or if only need one unit, replace that unit or get those old window units?
For portable aircons, remember you need a venting hose (trucking) to push the hot air outsince there’s no aircon that works without expelling hot air. Portable units are also noisy and take up room space.
As for air-coolers, that’s probably my last recommendation. Unless TS is staying in a small space like a utility room, where it might still do okay without aircon. But air-coolers come with their own issues like water leakage, noise, and space constraints.
Bro just put ice infront of fan will do.I mean those portable without trucking.. just pour water inside..something like that
TS can try loh ... shoppee is paradise for poorman, if got marnee go courts lolI think I tupelo wrongly, should be portable air cooler.
