- Sep 16, 2018
I don't see how that follows. How would a Cyber Security Label bar TP-Link from publishing a longer end date? That label sets minimum standards, not maximum ones.
Maybe, but that's not what TP-Link has published. Thus far they're unwilling to put more than mediocrity in writing — and mediocrity is a charitable description.
I totally understand your concern.
Unfortunately as of now, in terms of consumer WiFi 7 routers, TP-Link seems to be the most cost-effective vendor now in Singapore and many other parts of the world, now that Asus and Netgear WiFi 7 routers tend to be more expensive, especially 10Gbps capable models.
Personally I was using OpenWRT mini PC as the main router plus Asus RT-AX86U as AP previously. Now I use OpenWRT mini PC as the main router plus TP-Link Archer BE805 (bought at S$300 from an M1 user) or Asus TUF-BE6500 as main AP. It is difficult to beat the value of Archer BE805 (10G capable, triband WiFi 7 BE19000) with Asus or other brand.
It is even more difficult to beat the value of TP-Link HB710 (bought at S$192 from Starhub, dual 10G ports, triband WiFi 7 BE18000, 4 years HW warranty) if you are a Starhub user. In fact it also works with other ISPs. And Carousell resale price is lower than S$192.
