Singtel 10Gbps ZTE F8648P superadmin password.
ah_cleo
Hi all, had a ZTE F8648P ONR with the latest firmware which did not show the port bridging options. However, I did manage to find it.
Following the instructions from here: https://forums.hardwarezone.com.sg/...8p-superadmin-password.6946718/post-154220874
Visting the FastSetting page does not show the LAN ports for bridging, however you can right click and inspect element, search for a HTML element with an id of "BridgePort"
Delete `display: none;` from the style attribute by clicking on the style attribute and just hitting backspace until it is gone, then hit Enter to save. After that, you should be able to see this:
You can then follow the same instructions in the attached post (e.g. tick LAN5, then submit and reboot).
Afterwards, it should look like this if you visit the same page and delete the `display: none;` again.
All should be good and you shouldn't have double NAT anymore.
good news! thanks for sharing!!!! i tried and it works after restart the ONR.
Jus curious, need to do anything about TR069?
Just reset the ONR, lost the fix line, but able to login to support account.
So it must be Whizcomms technician changed the support password.
Were you able to get your v2.1.10P5N20B ONR bridged? I have the same problem where the reversed support password did not work. To make things worse the ONR does not even have an option to turn on DMZ! Any help is appreciated.
lhseong
Yes, able to bridged by following the steps. When bridged, the other LAN ports has no internet.
12521252
Thank you. It worked and i managed to bridge the ONR as well. Strange that they bothered to change the password on this version.
JamesZhang1220
Hi all, currently using a ZTE F8648P ONR with the latest FW and Xiaomi AX10000 router. I'd like to enable bridge mode and change the Xiaomi router to PPPoE. I followed Xiaofan's instruction, tick LAN5, then submit and reboot. My device lost network connection immediately, seems to mean that bridging was unsuccessful.
In addition, when I set up PPPoE in the router, it asks for a PPP username and password. Where can I find them?
Your Xiaomi router should not use PPPoE, rather it should be DHCP.
Singapore ISPs do not use PPPoE.
JamesZhang1220
Thanks for the info, I'll give it another try. I'm trying to access my NAS device using IPv4 and I'm having trouble getting it working. T-T
GamerZ
Did anyone try to login to the support account when the Singtel came to install just to make sure the reverse password works?
wangjx
Hi I am getting the exact same version as yours, support password also not working.
Wondering internet works after reset? Do I need to save anything and reconfigure it after reset? Thanks!
lhseong
I did not save anything and just reset
tidus792
Posting here to confirm that the current bridging instructions still work and I didn’t need to restart the router.
Android TV still works on any of the other ports.
I got a new IP v4 address after doing so.
No IPV6. (Using HB810)
Don’t blindly click the bridge option without following the instruction.
I can confirm that doesn’t work at all.
The TV will show a code 150 error.
Thanks for everybody hard work over the months.
royfrosty
I'm here to report. Current ZTE ONR for Singtel with the support login. ONT option is available out of the box without doing any special coding.
poland_ball
Sorry what do you mean by this? The bridge option shows up again without having to unhide it?
tidus792
I am very sure what he meant was you see the ONT option without modifying the page.
However that ONT option does not work (I tried it myself).
