ah_cleo
- Oct 9, 2005
good news! thanks for sharing!!!! i tried and it works after restart the ONR.Hi all, had a ZTE F8648P ONR with the latest firmware which did not show the port bridging options. However, I did manage to find it.
Following the instructions from here: https://forums.hardwarezone.com.sg/...8p-superadmin-password.6946718/post-154220874
Visting the FastSetting page does not show the LAN ports for bridging, however you can right click and inspect element, search for a HTML element with an id of "BridgePort"
Delete `display: none;` from the style attribute by clicking on the style attribute and just hitting backspace until it is gone, then hit Enter to save. After that, you should be able to see this:
You can then follow the same instructions in the attached post (e.g. tick LAN5, then submit and reboot).
Afterwards, it should look like this if you visit the same page and delete the `display: none;` again.
All should be good and you shouldn't have double NAT anymore.
Jus curious, need to do anything about TR069?
