[NEED EXPERTS HELP] Any most bang for bucks lappy can sic , preferably under $1K. But max budget notch more than $1.5K
eyz
just get aftershock sua
https://aftershockpc.com/series/lunar-14
2 years warranty, lifetime dust cleaning and cpu thermal paste change.
CPU
AMD® Ryzen™ 7 8845HS (8 Cores)
GPU
AMD Radeon™ 780M
RAM
2x SODIMM Sockets, support for up to DDR5 5600MHz
Up to 32GB Max with 2 x 16GB modules (5600 MHz)
Storage
2 Slot M.2 PCIe NVMe
Display
14" 16:10 2880 x1800 Display, 100% sRGB, 120Hz
Weight/Dimensions
~1.4 KG ±5%
313 x 220 x 16.95 mm
Battery
80 WHR
WarMage87
2nd hand mai la , dunno gotch what "hidden" problems they may hab as dunno how the previous user handle/use the laptop before
Moi thinking of long-term use, so why take chances with "pre-loved" items regardless their condition
Moreover use gahmen-gib money, so thinking dun be so hard on moiself
:o :o
Be selective about who you deal with lah aiyo.
tian_yibang
Acers are usually the more affordable (read: cheap) laptop options
Ultra 5 is the latest Lunar Lake Intel CPU. It is more power efficient (consume less battery, so your battery lasts longer), and it comes with NPU to help AI software.
Hmmmm
So whats the diff of this simi Ultra 5 and the normal i5 ?
toolbox03
Moi ish lappy noob, so quite dunno where to start from specs or function wise
So nong story short, any MS Windows laptops that "worth every cents" for a $1K budget ?
Preferably something notch more bigger than 14" as moi hab space constraints , and at least a 24/512 for futureproof use
Thinking wanna use the SG60V to get a lappy, but the Big 3 major stores and Challenger all dun accept so bopian later need use from GSTCash
https://www.hardwarezone.com.sg/pc/laptops/tech-news-microsoft-new-surface-devices-specs-price
The latest surface pro less than $1.5k
tian_yibang
TS got time go see see I remember got laptop under $1k for basic use.
Gaming laptop wise definetely above $1k.
Go for at least AMD Ryzen 5 with IGP will do for basic use.
Example this around $600.
https://www.harveynorman.com.sg/com...14-inch-laptop-green-grey-e1404fa-nk262w.html
Once you get GST voucher can just go buy.
Actually the RAM can upgrade or not.. I see the 8GB is like sibei ridiculous... bare bones minimum should be 16GB... sweet spot should be minimum 32GB
Yeah , if they gotch "free" upgrade to 16gb then can consider bai at this pricing
It seems 16gb ish the least smelly smelly must get huan
:o :o
cosmothecat
Hmmmm
This is the difference:
Meaning older normal i5 consume more battery power, doesn't have NPU, hence AI software works slowly.
cosmothecat
8gb still ok for most tasks
there is no need to deliberately spend more money
Not for Windows 11. Minimum RAM for decent performance is 16GB.
Windows 11 is a resource hog, just loading the basic Windows 11 OS core already using a fixed 7.2GB of memory. GPGT, see below. If your laptop only has 8GB of RAM, opening a simple web browser will also cause the system to swap out memory content from RAM to SSD/HDD, which will cause your laptop to lag.
bakuten
first of all.....you need to ask yourself these questions.
what do you foresee your usage pattern for the laptop will be?
issit just surf EDMW and beo tiktok/youtube beedios?
or u intend to pak AAA games with the laptop? or just light gaming on e-sports title?
will you be lugging the device around often?
is battery life important to how you will be using the device?
caterham7
Cool, but somehow I don't see lag on my 8gb windows devices
Maybe there are other factors involved?
bakuten
CPU
GPU
AMD Radeon™ 780M
RAM
Storage
Display
Weight/Dimensions
~1.4 KG ±5%
Battery
80 WHR
i bought before 2nd hand aftershock.....also got lifetime dust cleaning and thermal paste change. best purchase ever lol
