- Sep 16, 2018
XGS-PON ONT vs XGS-POB ONR can affect your network configuration by a lot.
Just to add on, XGS-PON (ONT) is capable of 10Gbps. So basically there will be 1 10Gbps port in a ONT while the rest will not be used. In the case of an ONR, it will usually be 1x10Gbps and 3 or 4 1Gbps ports. depending on the ONR model.
This is an important info for many users, especially for those with a DB Box not in the central location (most likely cases for BTO flat).
1) XGS-PON ONT: single 10G port active, other 1G ports are disabled. Usually you will need to put a router in the DB Box to utilize the room LAN ports (there are workaround but may not be easy for average users). Most power users will go with ONT.
Important fact: you cannot put an unmanaged switch in between the ONT and the main router. That will not work.
2) XGS-PON ONR: single 10G port active, other 1G ports are also enabled. It will act as the main router for your home network. It usually has FW features than typical 10G capable consumer routers. Power users will usually avoid ONR or will bridge the ONR.
Some average users may like ONR due to the fact they can save a router in the DB Box.
3) More on ONT vs ONR
https://forums.hardwarezone.com.sg/...cs-of-home-networking.6653421/#post-138363236
