That means wifi calling isn't active. If wifi calling is active you should see the wifi calling logo (samsung) and that you are connected to the telco.
Check that you have wifi calling correctly enabled. On some router/firewall you might also need to allow IKE/IPSec traffic.
But airplane mode isn't enabled in your screenshot. There is no SIM status to display if airplane mode is on, so you can't wifi call anyway
