Anyone started shopping using Pingduoduo 拼多多 App?
Foetid
The best way to view on desktop without having to log off from the phone is to install WeChat app for PC/Mac, then once installed, fired up and logged in from PC/Mac -> click on ’小程序‘ (it's 3rd from the bottom on the side panel on my Mac Wechat app)and u can open PDD. The format is like what u see on a phone lol... hilarous but infinitely more song than scrolling off phone screen :D
Thanks for the tips!
i have wechat installed for years but never knew can access the 小程序 this way. Even those metro apps i installed for various cities also popping up here. the PDD here is auto login liao...!
crandfs
The best way to view on desktop without having to log off from the phone is to install WeChat app for PC/Mac, then once installed, fired up and logged in on your PC/Mac -> click on ’小程序‘ (it's 3rd from the bottom on the side panel on my Mac Wechat app)and u can open PDD. The format is like what u see on a phone lol... hilarous but infinitely more song than scrolling off phone screen :D
Can just use this link https://mobile.pinduoduo.com
airman88
So far so good, same for the eye massage device, already use more than 1yr. I only experience usb charging cable that become faulty after a few month even though the product got a lot of good review and many buyers.
How does the eye massage device look like?
Krabs.
luggage wheel cover need to buy better quality
i bought most cheap quality , put on .... before trip it crack and break .... haven't even bring out ..... the silicone must have aged quite awhile at warehouse until stretch abit put on it damage liao .... it broke like 3-4 weeks after I put on
HougangKid
But, also don't make it a habit to ask for refunds every shipment for every item. The system do have a 'buyer grading' system in place to help deal with problematic buyers.
Heard from China side too many refunds will get your account blacklisted, but not sure how it's blacklisted. Could also be they don't give you access to discounts anymore.
netzach
HougangKid
Yes, once you install the app, micro transactions will start to appear on your credit card and packages will start appearing on your doorstep.
At first you'll think nothing of it, but slowly the transactions and packages will get more and more, and before you know it, it won't stop, unless you delete the app.
At the same time, it'll affect your Taobao app, makes it less and less useful until you hardly use it.
So safest is to better not to install at all. Dun say we never warn you.
Krabs.
just saw got paynow QR payment function ...... who tried ? how's the exchange rate calculated ?
nothinghere
install it on another phone (without banking apps, private apps such as whatsapp, etc.), do not connect it to home wifi, do not use as hotspot, do not put any important or private data, do not turn on location
best to use prepaid sim with number that is not important to you
it has been 3 years, but there must be a reason why its not reinstated on play store even after 3 years
the app can use, but treat the phone as if its compromised after installing, never install stuff like singpass or banking apps on it even after factory reset. you never know what kind of privilege escalation or persistence the app uses. if its serious enough even the sim can be cloned.
Jitter
install it on another phone (without banking apps, private apps such as whatsapp, etc.), do not connect it to home wifi, do not use as hotspot, do not put any important data
Buying simba data esim nao!
titusilvering
Just received yesterday. Very good, feel like real humans hand doing neck and upper back massage.
Can be use on arm and legs, just a bit difficult to secure to prevent it slipping away. Downside for neck massage you can only lie face down on the bed instead of face up. If you want to massage all at the same time, probably need to buy 4 or more units for both legs, hands and neck.
Not heavy?
Kitaro9202
杨子 brand have around 100-108 rmb
ok thank will go n see.
is it charge via type c?
was looking at xiaomi not sure if good
my house currenlty using this brand eluxgo but the suction like not powerful
