SET ST536v6 to bridge mode
cpuer
can asist how to set PPPoE in Linksys WRT54G Wireless Router?
Can't go into WRT54G homepage, how to set PPoE in router?
i hv set st536v6 to bridge mode.
The connection as below
st536v6 --> internet port on WRT54G ----> lan cable from WRT54G to PC ethernet port.
is this the correct setting?
thank you
you mean 192.168.1.1 wont get you to Linksys web gui?
oVerboost
Hi
I am using Speedtouch 536 and WRT54G too. I didnt bridge the Speedtouch 536.
My connection
Speedtouch 536 -----> WRT54G -----> Ethernet port of computer
This was what I did,
For the Speedtouch 536:
1] Go to the Web GUI \ Home Network \ Devices \ Assign the public IP of a connection to a LAN device [LAN device = Router]
*Note the static ip assigned to the router by the modem
For the WRT54G:
1] Internet Connection Type: Static IP
2] Internet IP Address: [the static IP as assigned to the router by the modem]
3] Subnet Mask: 255.255.255.0
4] Gateway: 192.168.1.254 [IP of speedtouch 536]
5] Static DNS 1: 192.168.1.254 [IP of speedtouch 536]
6] Disable DHCP server
The internet works. Have I done it correctly? Any comments?:s12:
ivanj
I've downloaded the residential CD
run and installed
keep on asking the user name and password.
tried what is mentioned in this thread to no avail.
UN: administrator
PW: Serial#
did a hard reset for several times already
hayyy still can't get it right
where did i go wrong?
will i ever set my modem to bridge mode? HELP
Fakken
Method 1
1. Hard reset the ST536v6
2. Connect to router WAN port
3. Set PPPoE
4. Surf the net
Method 2
1. Use Residential CD and set ST536v6 to bridge mode
2. Connect ST536v6 to WAN port of router
3. Set PPPoE
4. Surf the net
Certain people encounter problem using Method 1
I recently got the linksys WRT54Gv7 and have the speedtouch 536(i)v6. Read the posts here and was v confused. tried the bridging method, but the setup came out an error after promting to restart. Then i closed the setup and the com restarted. Waited a while, no continuing of setup came out as it said. V CONFUSED. Looking at method 1, those terms such as WAN port and PPPoE are kinda alien. could u guys help by giving a more idoit proof step by step guide? MUCH APPRECIATED! THANKS! :)
kelzy2k
any idea why during the installation it cant even detect the ethernet wire after i plug it into my com? However i can still surf the net.. >.<
tanhb71
Hi,
I just renew my SNBB contract and got this ST536v6 modem. I could not get it to work with my LinkSys router, I believe it is because this modem is also a gateway.
I have followed this link
http://forums.hardwarezone.com.sg/showthread.php?t=1908344
to tried using the Residential CD to set this modem to bridge mode but could not get pass the login page.
I have entered the below login information, both without success.
UserID: administrator
Password: "modem serial number"
or
Password: <blank> (no password)
Could someone tell me the password? Other then using the residential CD, is there any other way to set the modem to bridge mode?
Your help is greatly appreciated. Thank you.
tanhb71
administrator as 'Administrator'. note the caps
Thank you bro. I am now able to get passed the login screen and have successfully set my ST536v6 to bridge mode.
But I faced with another problem. How can I configure my modem, now in bridge mode, to do the dial in to my singnet account?
I have tried to access the modem configuration menu by typing "http://192.168.1.254" in my web browser, but unsuccessful, as it is no more a gateway I think. I have tried using the SmartWizard CD that come with the modem and was unable to detect the modem. The SmartWizard was able to detect the modem before I turn it off to bridge mode using the residential CD.
So, how can I configure my modem to do the dial-in in bridge mode? Thank you.
humcheepeng
After you have set the modem to bridge mode, you don't have to set dial-in configuration on the modem anymore. Instead, go to your router configuration and choose PPPoE, and enter the dial-in configuration there. Your router will do the "dialling-in" when connected to your modem.
tanhb71
Thank you sir. Ya, I am aware that I can set my router to do the dialing in. Just trying to see whether I can get the modem to do the dial-in and my router set to DHCP, as my previous setup was in this configuration. Anyway, I have set my router to dial in and everything is working now.
Thank you everyone, you are much much more helpful than Singnet Technical Support. Haha...dun force me to switch service provider, Singnet. :mad:
liangtam
Can, by means of half bridge mode. The setting is supposedly easy but buggy. Not recommended.
kohler
UserID: Administrator
I have try to convert this modem into bridge mode but was also prompt with this userid and password menu . I don't have any luck going pass this part . Did i goes wrong here ?
tanhb71
'a' in lower case, not 'A'.
