emuji
- Jan 14, 2003
Hi anyone facing the same problem as me .... can't access itunes stores on my macbook pro..... someone said try to delete a file from itunes under preference but the file is not there at all. tried resetting the keys as stated on apple website din work too![]()
maybe u should download & install the latest copy of itunes, set-up your account and try. that's what i do when hiccups like this occurs.
cannot copy files on desktop to ext hdd
error message
The Finder can’t complete the operation because some data in “School” can’t be read or written.
(Error code -36)
Anyone?
r u using windows-formatted ext. hdd? if yes, u need to install NTFS-3G/MacFuse. or just format the hdd to mac if you haven't done so, provided that you do not intend use the hdd with windows machines.
