Samsung Galaxy note 2 tips & tricks plus issues.
kennyboy
so meaning all the apps i download will auto go to internal??
Sianzz... no enuff storage liao...
I just bought a 64gb microSD just now:(
All apps will auto install to internal, no easy/built in way to move to external sd.
Store all other media to external sd lor......such is life for all current Android devices.
cheeyen
anyone know what does H+ stands for? and other icons... cause i never ever see the 4g icon before
JX1983
Hi would like to ask if anyone got this problem to update? I try to update my note 2 but it prompt me that my device had been modified.. software updates are not available.. my note 2 i didnt do anything also how come modified..
Then I tried my wife set but hers can update..
tohchr
Yes thank for your 指點迷經.. but can you answer to my first question?
3G = 3G
H = little tiny bit better speed or else same as 3G
H+ = Some said its considered 3.5G
G = Normal people will know its 2G network. Dirty minded one will think its a G String... :D
cheeyen
thanks.. was watching video all the way in mrt.. then when try surfing realise the cant even surf.. got 3G full bar but facebook not loading, then suddenly even g also dont have.. then after awhile H+ but also cant load.. restart phone also same.. on M1
laughingman
Guys,
Anyone encounter similar issue as me that calendar or task reminders not sounding off at the pre-set time.
And i have been able to replicate it. It happens only after i reboot my phone.
1)Set calendar event/task with reminder at 5 min later.
2)Reboot phone.
Reminder confirm wont go off. If i did not reboot phone then it will go off.
Also, after reboot phone, calendar settings like alarm notification sound will reset back to default.
On starhub ALJ5.
Silverback84
Hi guys... I'm having some problems with my note 2.
Itchy hand used the mobile odin to flash the newer stock roms few hours back.
after flashing the stock rom, no SIM card detected.
Already tried remove and insert SIM card, remove battery, reboot etc.
Still same.
Tried Factory reset using the boot recovery, still same.
Using boot recovery, tried to re-flash the newer stock rom and older stock rom from SammyMobile, keep getting Signature Error.
Now my note 2 can't be recognised using usb on both my PC (Win XP) and notebook (win 7). So I can't use ODIN to to do recovery.
Any one encountered before?
My last resort is to go service centre, but not sure if can get it repaired, or get it back in time before my holiday trip next tuesday.
Thanks in advance.
Edit: Win XP not Win 98
go read xda forum
Haar-b
My Hotmail works fine, but my company domain email damn weird... Always prompting for password from time to time despite all the setting are done properly -_-[/QUOTE
I got this problem for my company mail once in a while. Hotmail ok too.
:s11:
By the way, anyone know how to set the email signature? I cant seem to find it. I can do so when I was using Galaxy Tab.
cheeyen
Anyone had any idea for the drama/movies that we dl in PPS are we able to transfer the files into sd card?
tohchr
Guys,
2)Reboot phone.
On starhub ALJ5.
I am using exchange for my calendar. The task got problem where will not notify when I clear tasks. But using Events, no problem at all.. I guess your problem also within task and not events.
Collectible
who here face same problem for scrabble with friends.
i deleted it because it was pretty lag.
fireblade08
Hi, juz switch to note2 from Ip4. My note2 prompt me for software update, wondering should I update? Anyone done so?
monokuro
Anyone experiences app crash on note 2?
Can note charger be used on note 2?
What's a local set btw?
klutz89
1h15mins to charge 20%.
something is wrong with this right? Anyone with same issues? 3 day old samsung note 2. using stock charger cable plugged to wall socket
justln
Using original Note 2 charger head + Note 2 USB cable?
i1magic
It will take about 2h15m to 2h30m to charge from 0% to 100%.
So assuming worst case ... 30min ~ 20%.
The original Samsung Galaxy Note 2 battery output is 2A. Please check the charger you have whether is it 2A. Also do you have another charger with 1A, charge with it and see how long it takes.
jinsianzar
:s11:
Go to Email, Menu, Settings. Select the email account > Signature
