[Singtel] 2Wire 5012NV-002 (MIO Black Modem)
AhzOnG
anyone know if its possible to do network traffic monitoring for the 5012NV gw?
I can't find the community string in the control panel
jming_sg
Hi zorrus,
Can you share how to access the mdc page for 5012nv or any special address? I try to bypass the @singnet in username to use this modem in the other ISP.
Thanks a lot,
hk7310
Hi zorrus,
Thanks a lot,
from web gui enter 192.168.1.254/singtel, when ask for password: techsupport
jming_sg
Thanks for your assistance, hk7310!
I can see there are 3 additional tabs under "Settings-> Boardband" after login to "192.168.1.254/singtel". But still I can't bypass "@singnet" in "Link Configuration" tab...
I read the old posts, somebody mentioned that "You need to configure via a special HURL page to bypass Auto "@singnet" ". I wish to do so by login to the mdc page as 2701 but it seems not the right way.
Can anyone help to remember which special HURL page to go on 5012?
Cheers,
SlothySloth
this pace router is old or new one? previously my 2wire working fine. until upgrade plan they pcb give me this router keep reset. tried the method in the earlier post, hopefully it works. they blame my phone for being the problem, say wait for firmware fix. -_-
ERT
Can a 2Wire 5012NV with SingTel firmware be configured to work with the HG836 ONT on a MyRepublic connection?
I've changed the Link Configuration type to Ethernet and Connection Type to DHCP (Dynamic IP) but the router is unable to acquire a WAN IP from the ONT.
HeyApple
Had this problem for quite awhile.
Previously was on 6mpbs plan with singtel. So recontacted with them last year to 16mpbs using the black mio 2wire.
Problem is, my download speed with the 6mpbs plan was 2.1mb. After upgrading my plan. The download is still the same, 2.1mb.
Anyone knows why and where went wrong? Paying for 30 dollars more but same speed.
deathblade82
Firmware ver ? Were u prev on ST fiber ? Heard that they hard coded the VLAN tags into the firmware. So can't use. Unless u drop it to a older ver.
deathblade82
Have u contacted ST helpdesk ? Using for 1 yr and nvr make noise abt it ?
Pls note all test muz be done via wire to ensure accuracy. And note the diff between mb (bits) & MB (bytes).
HeyApple
Hasnt contacted st helpdesk. Just wanna ask if the problem is on my side or on theirs.
Tried downloading with wired. Speed wise is still the same.
I'm not sure about the bits and bytes. But in any case, when i upgrade the plan, the speed should be faster..
deathblade82
Not necessary. What if they did not make the backend changes ? Or is it due to line issue ? Pls note that adsl is still susceptible to interferance.
HeyApple
So should I just dial 1688 and speak to the customer officer or is there any special departments should I request for?
deathblade82
Yes, pls do so. If not you will be at the losing end. Direct to the tech support for ADSL wld have faster respone, i suppose.
HeyApple
Hi guys, Please pardon my noobness here.
As from the first picture, it shows that the download is only 2.1 but the speed test shows 18?
eng10929
My connection is ONT - 2 Wire in bridge mode - my own router. It was working well since last April.
A few days ago, I have asked Singtel to upgrade my 100mbps fiber to 150mbps.
They told me it will be upgraded on Thur (today).
This morning, my router is not able to get IP. I have switched on/off the ONT, 2 wire and my own router a few times and still facing the same problem.
Anyone knows what the problem is? How do I troubleshot? Shall I call singtel tech support?
Thanks a lot!
eng10929
Thanks a lot!
Problem solved...
I connected my laptop to 2 wire directly, it's able to get IP, and access the internet.
I tried connect my router to 2 wire, it's still not getting IP.
Then I openned my router setup page, and changed the mac to some random mac. Amazingly, my router was able to get IP.:s12:
However, if I try to use the default mac of my router, it cannot get IP again...:s22:
Anyway, I'm going to use the random IP...=:p
noelnoel
Sometime I have problem getting ip addresses from the DHCP. I was forced to use statics IP instead and now is stable.
hi, have you managed to solve this problem?
* problem gone after i restarted my modem the 3rd time
