And that's actually quite different from what I had posted above.
" accurate only from around 40C onwards" ie. inaccurate below ~40C, more accurate above ~40C
Most DTS on CPUs are calibrated to get more accurate the closer it gets to the throttling temperature (the primary reason for having the DTS ie. prevent thermal damage) and it's not just AMD. Intel CPUs have inaccurate idle DTS readings too and some have even stuck idle DTS as well ie. the DTS does not read below a certain value even if you cool it down further.
All in, the DTS purposes to serve more as a guide to trigger thermal throttling in the CPU and not so much for reading idle temps.
HTH
i see. thanks for sharing man.
