standarture
- Feb 28, 2009
The grind size is the most important.
yeah taka, without the espresso machine is 349.
Its a good starter combo, if you can get pass the aluminium boiler.
Also, when you say 'starter', means you plan to upgrade in the future. Keep in mind that in sg there's no market for 2nd hand espresso machines so it'll be hard to off-load when the time comes.
I think these type of machine kena pawn by those nespresso one.
Ppl all want convenience and just want to press 1 button
I'm still looking around for the grinder. Read the Baratza vario has good reviews or should I get the macap m4/5. Read the rocky is only able to use 2 settings for espresso.
Btw, not much places can get 240v devices except for espresso coffee shop which severely limit the choices.
The vario has some quality issues i read. I would get the macap m4.
If you don't mind manual, OE Pharos is very good.
BTW, any places that I can get beans that is convenient? I don't drive? Can just buy from cold storage/ coffee bean etc or must go specialty shops?
Cheers.
try fourtyhand, highlander, Toby's Estate ,cshh, Oriole , papa palheta.
never get from those pre pack ..............
Ok will check them outtry gumtree or some AMDK forums.
they are most likely to sell a espresso machine
OK got it. I read the macap built like a tank. What's the difference between m4 and m5? Price seems to be the same at expresscoffeeshop.
BTW, if say I got a hario slim, do you think if chiamseetong is it consistent/fine enough for the rancilio? Because I'm making at most for me and my wife only.
Also, conical or flat burr any difference? Read it's "similar" depending on how it is designed.
Cheers.
Sun ray cafe roasts their beans every friday. Can consider.
sounds abit troublesome to buy 2nd hand machines from overseas.
have to make sure its ard 220v.
seller is willing to ship overseas.
can't check condition. have to trust the seller.
future replacement of parts have to source and fix yourself.
