Looking good! Can't wait to see the finished product
I might be doing my custom loop in Late 2014.too much poison.
Just purchased the items from AQC... Will update them when it arrives.. Total was 385 EURs.
why dont want get the active backplate? that one looks good![]()
Find it pointless? Top dun heat up as much as bottom... If i can cool the bottom VRM, then top dun really matter.
idk bout ram placement for 290 but on 780 the back heats up damn lot too like burning feeling even with thermal pads
Coz, u r OC too much le.... the backplate cant release the heat as fast the gpu is giving out.
For me, at most +100mV nia for 24/7. No point going that high. More things to consider in which i have not considered, such as heat output.
what's your res size and height?
did you drill holes for the fitting of the res?
your cable com from congrade bro ah?
cause i using same case as u and my lower rad shld be at the HDD cages there and i hang my hdd cages below my 5.25 bay.
your fill port just fill via the top rad?
btw the bitspower valve fittings is like tap ah? on and off?
off, insert tube, on, water will drain out?
I also planning to use XT45 for top rad and UT60 for bottom rad.
