Shion
Senior Mentor
- Oct 24, 2008
Will this one work?
Otherwise, I'll pop in to SLT on Mon to get it.
It needs to be connected to the end of this (the 2 metal thing)...
Will this one work?
Bro can share where u get the parts especially the socket part
You got show them the illustration? Cos when i first bought from them they don't even know its name. The auntie was like "So this is call BALUN transformer ah!"Can't buy the Balun transformer any longer from UF Tech in SLS... any idea where else I can get one? I asked a few shops in SLT even the one I made cables from and they don't carry it.
Putting the DIY antenna on practical...
Near the window facing towards Bukit Timah Hill (where transmitter originates)
Scanning and detecting succeed!
Crisp and clear image!
This is the Signal Strength and Quality even when the window is SHUTTED!
You don't actually need to buy any Margon, Amazon, Leaf, etc.. powered antenna to achieve this!
Some additional info: Home locates in Sengkang Compassvale, living on top floor. Signal is very strong and even penetrates way over into the middle of my bedroom where this TV situates. Old DVB-T signal can't even does that!
A small project as learned from this place...
1 set only cost roughly $2.70-2.90!![]()
Eh nope... unfortunately Mediacorp has currently no plans to broadcast the digital signals through the cable network that was built into all homes. For whatever reasons. But I suspect it is to ensure that FTA remains as that. But it's really irritating cos we're going back to the Stone Age with wires and antennas all over the place, one unit for every TV you have.
I have no idea why. The thing is if you subscribe to Starhub pay TV then you do not need the antenna. Which means that Starhub is obliged to carry the FTA signals for all pay-TV customers. Which then means that there are no technical restrictions. Which also means it is basically a commercial decision. And that also means that if MDA mandates that all signals must be carried through the cable network, then it will be possible. So who knows who made the stupid decision not to mandate that the signals be carried through the cable network or through the fibre network.
MDA already mandates cable operator to carry out FTA channels on cable network, just that they dun hv the newer HD version channels of Ch8, Suria, Vasan yet~ the rest of it already in digital for many yrs~
technical wise, its not an issue~ we had seen starhub testing HD8 & suria on ch154, 156 before~ only thing is whether will they make it free or encrypted~ even if its free, tv users still need DVB-C box or tv with built-in DVB-C, which makes the campaign on DVB-T2 looks poorly planned~![]()
Really contemplating on building the DIY antenna as i am hearing stuttering on audio every 10 secs or so when watching live tv on NPVR. Recording sounds fine though...
However my connectors are all those normal coaxial jacks. Not the screw on type...eg those behind tv, tv card or matv jack. So i think i need the one the ming ern suggested and link the copper wire directly to the paper clips
Can go find a screw on type adapter for your normal coaxial jack![]()
When come to the new FTA HD channels, non subscriber of starhub/mio have to use antenna. Is this because of technical issue that new FTA HD channels cannot be carry in cable network?
