Post your Yosemite issues
iamvinci
Trying to dl from App store, the traffic is really high, dl speed is super slow.
PetPet
Moderator
Moderator
Make sure you're not behind a public DNS (like google's) so that it can allocate a content farm that's closer to you. I've no problems downloading it just now. Got it within 20 minutes.
PetPet
Moderator
Moderator
not only that, status bar at the top can't switch to transparent mode... now my desktop and wallpaper don't fit...
Did you do a upgrade or a clean install?
Under accessibility -> uncheck reduce transparency.
maxheadroom
For those who upgrade SSD, the trim currently not working or have to disable the kext signing. (A kext is a kernel extension, or a driver, in Mac OS X). Temporary I not enable the trim for my mid2012 samsung SSD.
PetPet
Moderator
Moderator
If anyone is facing battery issues on your Macbook Pro.
Zap your PRAM.
2ulkifli
walau, my battery don't charge, aiyah... should not have upgraded. Did PRAM reset also not working. Sian man.
PetPet
Moderator
Moderator
Interesting.
What's your MacBook model?
Have you check the contacts to ensure they are clean?
Under System Information > Power. What does say about your battery condition?
2ulkifli
Did SMC reset 1st but didn't work and then did PRAM reset also didn't work. MacBookAir 13" 2011 model if I recall correctly, now holding back Yosemite upgrade on my 27" iMac.
Battery Information:
Model Information:
Serial Number: xxxxx
Manufacturer: SMP
Device Name: xxxx
Pack Lot Code: 0
PCB Lot Code: 0
Firmware Version: 406
Hardware Revision: 000a
Cell Revision: 162
Charge Information:
Charge Remaining (mAh): 5930
Fully Charged: Yes
Charging: No
Full Charge Capacity (mAh): 6127
Health Information:
Cycle Count: 66
Condition: Normal
Battery Installed: Yes
Amperage (mA): 0
Voltage (mV): 8212
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 10
Disk Sleep Timer (Minutes): 0
Display Sleep Timer (Minutes): 10
Wake on AC Change: No
Wake on Clamshell Open: Yes
Wake on LAN: Yes
Current Power Source: Yes
DarkWakeBackgroundTasks: 0
Display Sleep Uses Dim: Yes
PrioritizeNetworkReachabilityOverSleep: 0
Standby Delay: 4200
Standby Enabled: 1
Battery Power:
Display Sleep Timer (Minutes): 5
Reduce Brightness: Yes
Standby Delay: 4200
Standby Enabled: 1
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: Yes
Wattage (W): 45
Revision: 0x0000
Family: 0x00ba
Charging: No
derrickgoh
Hope they fixed the problem with trying to install Win 8.1 in Boot Camp via ISO and being told the system can only support Win 7. :s8:
