Post your Yosemite issues
Snoweagle
for those that have longer boot, do you have filevault enable? If yes try disabling.
Tried turning off mine but it said to wait until disk is fully encrypted before it can be turned off which is like a day left to complete. :s22:
PetPet
Moderator
Moderator
For those whole have problem downloading, should have redirect your DNS to google either 8.8.8.8 or 8.8.4.4 for both singtel and m1. I notice downloading to be very fast, even during my beta download.
My customer took 30min to download 5GBplus that encounter those download broke issue.
wow that's weird.
You shouldn't redirect it to 8.8.8.8 or 8.8.4.4
Because you'll most likely be assigned a US server instead of a SEA/Singapore server.
You can try creating a new user account and trying downloading it from the new user account's App Store. (at least that's what worked for a friend)
wychong
Nope.
Creating a new account does not work for me either.
Still waiting for a solution...
taongbundok
Airdrop on mba
the airdrop on my mba is not working.:sad::sad: it can't detect my iphone 6.
wychong
Yep, definitely a modem/router config issue thats giving me the 'pls download from Purchases page' thingy.
Did a hotspot connection from my iPhone's 4G Data plan, and installation starts without a hitch.
Of course i stop the download the moment it is 10s into it... must avoid unnecessary Data charges... :s13:
I am on M1 Fibre. And I have port forwarding setup... so any solutions from anyone? :(
2ulkifli
Posting my battery not charging solution, you are not going to believe this though but it's true. FYI, if you are going to attempt the same thing please just be aware that the MacbookAir uses a specialised screw set to open the bottom cover and another specialised set to remove the battery.
Anyway, I took out the battery did PRAM reset and still it didn't work, then how did I got mine to work was after I had reinserted the battery I just removed the MagSafe supply and of course that abruptly shutdown my MBA, put back the MagSafe in and press power button and now it is charging.
Weird, yes.. unbelievable, yes.. damn these buggy upgrades. This is now what my MBA shows:
Battery Information:
Model Information:
Serial Number: xxxxx
Manufacturer: SMP
Device Name: xxxxx
Pack Lot Code: 0
PCB Lot Code: 0
Firmware Version: 406
Hardware Revision: 000a
Cell Revision: 162
Charge Information:
Charge Remaining (mAh): 5632
Fully Charged: No
Charging: Yes
Full Charge Capacity (mAh): 5927
Health Information:
Cycle Count: 66
Condition: Normal
Battery Installed: Yes
Amperage (mA): 99
Voltage (mV): 8245
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 10
Disk Sleep Timer (Minutes): 0
Display Sleep Timer (Minutes): 10
Wake on AC Change: No
Wake on Clamshell Open: Yes
Wake on LAN: Yes
Current Power Source: Yes
DarkWakeBackgroundTasks: 0
Display Sleep Uses Dim: Yes
PrioritizeNetworkReachabilityOverSleep: 0
Standby Delay: 4200
Standby Enabled: 1
Battery Power:
Display Sleep Timer (Minutes): 5
Reduce Brightness: Yes
Standby Delay: 4200
Standby Enabled: 1
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: Yes
Charging: Yes
melvinchen
OS X 10.10 fixed some of the bugs found in OS X 10.9.5 but new bugs surfaced on OS X 10.10:s11:
Model Information:
Manufacturer: SMP
Device Name: xxxxx
Pack Lot Code: 0
PCB Lot Code: 0
Cell Revision: 162
Charge Information:
Fully Charged: No
Charging: Yes
Health Information:
Cycle Count: 66
Condition: Normal
Amperage (mA): 99
Voltage (mV): 8245
AC Power:
Wake on LAN: Yes
Standby Delay: 4200
Standby Enabled: 1
Battery Power:
Standby Delay: 4200
Standby Enabled: 1
UPS Installed: No
Connected: Yes
Charging: Yes
erwinrommel
So far Trim Enabler is the one that can be enable trim for yosemite. Degrade will not be so bad as what people might sound if disable.:s13: We just have to wait for a while.
I enabled it and now I can't boot in. A huge no entry sign is on the screen.
Now I have to go into recovery mode and restore back to Mavericks. :s22:
ashhong
I found yosemite quite smooth on my MBA but the start up time is now longer with a loading bar. Is that normal?
the loading bar is new right? i don't remember seeing loading bar in maverick or earlier.
overall performance seems to be the same as maverick on my aging mid 2010 mbp.
fusilli
Is there anyway to bring back the drop down list for navigating the tabs bar?? It's gone in Yosemite.
kenzone7
Everything looks OK, but just one thing. Can't get iPhone 6 calling to work on iMac (late 2012). It keeps giving me the message that iPhone and iMac are not on same wifi network, even though they obviously are. Checked all my settings... cellular calls enabled on iPhone's FaceTime app, iCloud account ID is the same across iMac and iPhone... But still the same error message comes up.
Not experiencing any syncing problems on other stuff like Safari iCloud tabs, just this darned phone call syncing feature. :s11:
maxheadroom
So far mine working great. Do restart your Idevice, sign off & on your apple ID and let your bluetooth on. At least it how during my beta 1 Yosemite troubleshooting.
Make sure you they connected the same bandwidth as well. 5ghz or 2.4ghz
Once you had success, be prepare that all your idevice ring together insane!!!
