bolasutra
I am also experiencing disconnect in 5G. Any advice what to do?
Speed is much slower.. Any advice what to do?
It seems that the performance is subpar compared to Aztech 7003. I am sure Asus can be better...
renfred89
What do u by disconnect? Whenever my phone sleeps it will disconnect me. Reconnect back qhen my screen is on.. is this the problem u r facing?
oric1
On Starhub 200Mbps plan, no problem with the AC87U. This is a very solid router. Prior to that, I was using N66U, now I bridged it to AC87U.
On Merlin's latest firmware Asuswrt-Merlin 376.48 is out - SmallNetBuilder Forums
While I'm performing these speedtest on the PC, iPad Air & iPhone 6 Plus, my family were streaming movies on the Samsung SmartTV and iPad Mini concurrently.
Windows 8.1 PC via Cat6 Cable
iPhone 6 Plus via 5Ghz
iPhone65Ghz_zps86ca7690.jpg~original
iPhone 6 Plus via 2.4Ghz
iPhone624Ghz_zps301d3d20.jpg~original
iPad Air via 5Ghz
iPad5Ghz_zps58318690.png~original
iPad Air via 2.4Ghz
iPad24Ghz_zps09660ddc.png~original
bolasutra
I was in the common toilet. Using 5G connection, the webpage shows invalid page at EDMW... Then I switched to 2.4G is ok.
Let me monitor these few days.
renfred89
Tuesday I'm going down to RMA already.. my 5Ghz will disappear randomly. Worse than ur toilet situation.
Btw what are u surfing in toilet? :p
bolasutra
Mine is 5GB still connected, yet shows invalid page. Anyway, I still can live with it. But I feel my Aztech 7003 seems to be performing better.
Route got the latest firmware from Asus. I just hanged on and wait for the next official firmware release. Least, I still can surf.
legolaz
Done in one of my room not far away from router. During the DL speedtest it n started from high Mbps then slowly decelerate and end with 50+ Mbps final result.
I have had the same problem as well. Download speed is 1/4 of the upload speed. Often about 50-60mbps vs upload of 200+.
In addition, it's very strange but for a month I had no issues with my connection but in the last 2 weeks, the wifi connection would just be cranky. Connection is fine but not Internet. When I turn off wifi on my iPad and iPhone and reconnect, it would suddenly be fine. Same for my asus Laptop. When I restart the router, it would be fine for 2 days before the problem happens again. Can anyone help?
vkel
Hi guys, i just bought the ac87u at the sitex, was unable to connect to my singtel fiber broadband, after going thru the helps here by my uncle, i was able to get the internet up.
But as i do not have miotv do i still have to set the " select ISP profile" to "singtel-others" because this setting the lan port 4 will be use for miotv right? Or i still can use it for my pc?
flep1
Media Bridge Between 2 Asus 87
Is it possible to connect lan cable between 87 (Bridge) and the Fiber Modem. And the second 87 (wireless router) at the center position in my house? Can it work this way?
jehkoh
Weird internet speed with AC87U
I have the AC87U and the speed of the 5ghz is very unstable. Did a speedtest and the results are download: 52.22mbps and upload at 206.60mbps. Anybody have any advises? Out of my wits. Any settings to set to balance my upload and download speed? I am on Singtel fibre 200mbps plan
renfred89
First of all, which firmware are you using?
What devices are connected to it?
Well generally, ur results are kinda similar to mine..
jehkoh
Firmware :3.0.0.4.376_2769, connected to 5ghz network through my desktop, PCE- AC68 802.11AC network adapter. Router is 3meters away from my setup. Can't figure out why the extreme slow download speed. Any help? my download speed has always been slower than upload. any reason why??
renfred89
Mine too.. after much research, its the firmware limiting it.. for my 200mbps, my download is always around 150 ish and upload ard 224mbps.. i guess we could only wait a while more for a stable release..
legolaz
Why do you say it's the firmware issue? Others using the same firmware has no issue. Would really appreciate if anyone could shed any light.
cscs3
This happen to many series of ASUS router.
The only way to fix it is move to other brand.
renfred89
not many options for me, as not many support vlan tagging...
After replacing the faulty one, this replaced router does not cause the 5Ghz band to be undiscoverable for no reason.. So yeah, my old router was faulty.
But this new one inherits the usual kns 5Ghz performance, but then again, what else can i do..
renfred89
if you read wide enough, independent experts have mentioned about the firmware causing such meagre performance. Some other users may not face the same problem as they are not using the same configuration and wireless clients as you.
if you could find a way to overcome this, share with us..
bolasutra
So far, I have quite happy with the performance such as wifi coverage. But for 5G, my device got disconnected for no reason. Anyone got this symptom? How to solve it?
guni_man
iPad Air via 5Ghz
iPad Air via 2.4Ghz
What firmware are you on?
