renfred89
Dear all,
RT-AC87U: 3.0.0.4_378_5134 Unofficial beta
Changelog:
Update: QIS ver. 1.5
Update: traffic monitor
Fix: reduce media server memory usage
Fix: [Media Bridge] Can't connect to P-AP by 5GHz DFS channel
Fix: [USB Application][Media Server - Windows media player
Fix: WAN Status LED
* No hard reset require from build 4950
Download: http://goo.gl/ppJuct
Best regard,
JK
5134 is pretty much stable, i encourage all users to try..
But for the wireless-professional page, you will have a floating support bubble:
Most likely an UI glitch. tested on mac 10.10.3, with safari and google chrome browser.
thiamhui
The actual content of those "floating support" are still downloading. It will goes away once it is done.
Previous version also had this issue.
renfred89
Ehy, the change log doesn't say anything about fixing wireless issue - just mostly usb media server fixes
flashing it now
hahas i also never say it fixes your wireless problems.. just saying its a stable beta for users to try.. :s13::s13:
seller4
I called Myrepublic and escalated the issue. They claimed they are aware of the issue and is looking n fixing it. ETA for fix in 24 to 48 hours. If 48 hours still like that, we can all call in n give them a peace of our mind. :s13:
MR fixed the issue liao. Upload speed is back to normal for all my Android devices. :D
thiamhui
Dear all,
Changelog:
Fix: WAN Status LED
Best regard,
JK
DDNS issue reported at http://forums.hardwarezone.com.sg/i...]-asus-rt-ac87u-4781419-183.html#post92964726 is still not fix.
thiamhui
Dear Thiamhui,
We can confirm DDNS is working fine.
Tested by many user.
Please do not use restore settings
Best regard,
JK
DDNS itself is working, just that the DDNS hostname would become corrupted after backing up the router configuration.
ov2rey
Err… I didn't restore any configure setting onto the 4950 firmware.
JK already said if you restore configure settings save before 4950 then you cannot restore.
I don't recommend use restore configure settingws.
thiamhui
I have a habit to make a backup of configuration in case I need to reset and restore on the same firmware version.
Anyway, this issue was also discovered on Asuswrt-Merlin firmware and was fixed.
http://asuswrt.lostrealm.ca/changelog said:
378.52_2 (5-Apr-2015)
- CHANGED: Updated AiCloud prebuilt binaries for MIPS models
- CHANGED: Applied kernel patch for MIPS kernel ported from 376_3861,
related to CTF support
- FIXED: AiCloud would fail to start unless you had HTTPS enabled for
the webui (causing the key/cert to be missing)
- FIXED: DDNS hostname would become corrupted after backing up
your router configuration (Asus bug)
ASUS@SG
Suspended
Dear Thiamhui,
Please take note: If the firmware required hard reset and please do not use restore feature, due to some coding may change and it will cause the router unstable.
Best regard,
JK
