StarHub MaxInfinity Fiber Optic - Experience
bjornng
okay! that means i am on direct ont. so i can just plug and play the new asus ac68u/ac87u right?
bjornng
alright. thanks for your help.
saw from marketplace asus n56u bnib going for like $70 only.assuming i get it and use it as my main router, remove the dir 868l (not for repeater too), would it be a wise choice? considering its just wireless N. but i usually check my dlink web interface, most of my devices are connected through N, because of the short 5.ghz range.
or should just go all the way for ac68u? :) hahaha
Gribber
AC68U la. Future proof.
N56U for $70 abit steep as well. :)
bjornng
hey guys. how does a homeplug work? technically, it's a power line repeater..?
was reading through this forum, and saw this Sineoji thread. seems like the reviews of it are pretty good, their support services is quite prompt too!
Humster
Anyone having random DC and packet loss every few minutes since 0930am?
Bukit Panjang.
Fiber 300mbps
melvinchen
It uses your home power line to carry network packets.
Gribber
yup, Sineoji service is really good imo. Their powerplugs are pretty decent as well, if not - the best.
then again, Powerplug relies greatly on your home electrical wiring. Lousy wiring = lousy input / frequent DCs.
halocast
Hi reporting my newly upgraded line.
Dlink router 868L, on the new VEONT.
So far so good, the wireless perf is better than my old N router 655. same for wired
Now just let it run to see stability :D
bjornng
DON'T off your router and modem. the first day of installation, everything was good, next day all crash. SH reasoning is because when installing, it is a temporary connection. nxt day all haywire as SH backend havent complete the order. after the first day, i've been constantly facing weak signal with the dir 868l.
halocast
Noted will keep it on :s12:
ohmygod1986
No point to on off also...
On 24/7/365
Sent from using GAGT
bjornng
yeah. only thing is my dad will off it. when i already tell him don't off.. sian
dlink dir 868l router got this problem of the orange globe light after restart, will never turn green. need to wired connection and login to the router page and renew/release ip before it turns green.
Gribber
Think something is wrong with your set
As well as, you can always log in to router page via wireless.
bjornng
this is the rma set already. dk if it's refurbished or what. but i've met other users who are in the same situation as me.
how to login via wireless??
halocast
Reporting in..
didn't left my set on overnight.
today turn on. no issues.
i believe yr set got problem.
will monitor my set and keep updated here
Gribber
same as how you login via wired lo.
The gateway IP ma.
